Repairing Leaking Sprinkler Pipe Elbow - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-23-2017, 03:27 PM   #1
Rewards Points: 2
Repairing leaking sprinkler pipe elbow
I have an in-ground sprinkler that has been leaking from below. Today I dug out around it, and found what looks like a cracked black pipe elbow. However, it doesn't look like any of the sprinkler piping parts I've found at the store so far. I'm not sure if I'm just looking for the wrong thing, or this is obsolete and not carried by the big box home improvement stores, or what.
I haven't removed it from the ground yet because I'm not sure how it comes off. I'm also a little bit hesitant to dig a lot more before figuring out if I can just get a drop-in replacement; if this is going to be a bigger project than that, I might ask my gardener to deal with it.
Any guidance on what the proper term for this is, and any tips on replacing it?
I have a picture, but apparently I'm not allowed to post pictures here yet. I'll try in a follow-up post...
sch9171 is offline   Reply With Quote
Old 04-23-2017, 04:24 PM   #2
JUSTA MEMBER
Rewards Points: 12
Re: Repairing leaking sprinkler pipe elbow
Any chance that this system was installed by a commercial contractor?
Contractors use different tubing and connectors than is available at the BOX stores, so you might call a sprinkler installer for repairs.
ED
de-nagorg is online now   Reply With Quote
Old 04-23-2017, 07:20 PM   #3
Rewards Points: 200
Look up swing pipe fittings.
https://www.sprinklerwarehouse.com/S...ings-s/228.htm
Dan
djlandkpl is online now   Reply With Quote
Sprinkler valve leaking pisano772 Landscaping & Lawn Care 2 04-27-2017 05:11 PM
What is this pipe and how do I stop it from leaking? jcp988 Plumbing 5 04-12-2017 11:49 AM
New Home Pipe Outside Leaking NOT AC aidan80 Plumbing 10 02-20-2017 09:33 AM
Could you give advice on a leaking lead pipe supply line? markcal02 Plumbing 3 10-18-2011 09:03 AM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 02:36 PM
