Relocate Or Replace Vinyl Fence Posts - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-08-2014, 07:16 PM   #1
Rewards Points: 251
Relocate or Replace Vinyl Fence Posts
Hello,
I have a line of vinyl horse fence that I need to move a few feet over (specifically, ten 5"x5" hollow square posts after the rails are taken out). The ground is pretty rough here, so it is worth it in the long run to dig these posts out and relocate them with the concrete chunks attached or just buy new posts? I will have access to a backhoe and auger.
Peace,
Dr. Z.
Zeigh is offline   Reply With Quote
Old 10-08-2014, 11:27 PM   #2
JUSTA MEMBER
Rewards Points: 106
You will have a Dicken's of a time getting them reset properly with the concrete on them. Unless the concrete is easily broken away.
More feasible to build new with wood posts, then saw off the vinyl and slide right over the wood. This may be how it is built already, need to look it over.
Might you add your location to your description to the left of your question?
This aids the talent here in giving more accurate aid. THANKS
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
fuzzmanks (10-16-2014)
Old 10-08-2014, 11:44 PM   #3
Rewards Points: 251
Originally Posted by de-nagorg View Post
More feasible to build new with wood posts, then saw off the vinyl and slide right over the wood. ED
De-Nagorg,
HA, what a great idea!
Yes, the current posts are nothing but vinyl stuck right in concrete, so I could simply cut the posts off at ground level. Then I could reuse them with a custom made "mounting peg" that they slip right over. THANKS!
Why do I keep hearing this phrase in my head all the time; "Keep it simple, stupid"?
Peace,
Dr. Z.
The Following 2 Users Say Thank You to Zeigh For This Useful Post:
de-nagorg (10-09-2014), oh'mike (10-09-2014)
Old 10-09-2014, 10:00 AM   #4
JUSTA MEMBER
Rewards Points: 106
Thank you for the address addition.
Seems to me that the vinyl posts stuck in concrete is not very strong. Sure hope that you are not planning to have a horse or two in there. But with the wooden posts as a center it will be much stronger.
Am glad that you like the suggestion of a wood post inside the vinyl.
ED
Existing Vinyl Fence, Add Lattice to top? benlittle Landscaping & Lawn Care 4 07-18-2013 10:33 PM
Vinal fence support posts songbirdkim Landscaping & Lawn Care 0 04-28-2011 09:54 AM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 02:42 PM
Replace Outside Corner Posts? HomeOwnerNewbie Building & Construction 3 05-22-2010 07:33 AM
vinyl fence installation dedsr Landscaping & Lawn Care 3 12-10-2004 10:59 PM
