Is This Redwood Fencing With Water Damage? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-18-2015, 07:40 PM   #1
Rewards Points: 4
Is this redwood fencing with water damage?
Hi All,
I'm hoping someone can tell me something about this redwood fence.
I recently had a redwood fence installed and it kinda sorta fell apart the next day... and for the next couple months until the company finally came out to fix it.
What I mean by "fell apart", is that the knot holes fell out, some of the planks split straight up the middle and by the time the sales rep came out, even he said I had a swiss cheese fence (his words). When I say "fixed it" I mean that they replaced some of the boards with holes in them... but not every board. Also, I started seeing what looked like water damage on every plank coming from the top down and bottom up. There are no sprinklers by the fence and the fence doesn't even touch the ground. And like I said, it's also happening from the top down on every plank. Plus, I live in CA and it hasn't rained here since they installed the fence (yes, it's been months).
What I know:
I had a good neighbor fence installed with kick boards (I'm going to try to attach a pic).
The owner of the company said the batch of wood was a bad batch.
I paid for con heart wood (even I don't believe that that is what was actually installed).
What I want to know:
What is this damage? Is it a result of the bad batch? Is it dry rot? What do you think, should the company replace the whole fence? The water damage is only on the originally installed boards (the bad batch), not the boards that were replaced. Which is why I'm asking what it is.
Thanks to anyone who can help. Getting this fence installed has taken far too much of my time.
Is this redwood fencing with water damage?-frence-pic-1.jpg   Is this redwood fencing with water damage?-fence-pic-2.jpg
lgal is offline   Reply With Quote
Old 08-18-2015, 08:09 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 132
I'm no expert on water damage, but that sure looks like it to me. I know you haven't had any rain out there for quite some time, but, the bottom picture looks like water has "wicked" up through the bottom boards. I'm mystified as to how the water stains came to be at the top, very strange.
It could very well be water staining from sitting out in some lumberyard somewhere. I know I have purchased fence panels before that were just sitting out in a giant puddle in the middle of a Carter lumber yard, no telling where yours may have been before they were installed at your house.
One remedy would be to stain with a solid stain to blend in that mess. I would be leery of using anything water-based because it may wick those stains through the finish coats.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
lgal (08-18-2015)
Old 08-18-2015, 09:36 PM   #3
Property Mgt/Maint
Rewards Points: 7,058
Are the horizontal upper and lower boards treated lumber? Treated lumber is notoriously super wet when new. Possible the kiln dry redwood is pulling the moisture out of the treated boards.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 08-18-2015, 10:13 PM   #4
Rewards Points: 4
Nope. Regular redwood. The only treated wood on the fence are the 4x6 posts. Those are treated redwood.
Old 08-18-2015, 11:45 PM   #5
Rewards Points: 5,348
Looks like the vertical slats are resting on the wood at the bottom and water is wicking up the end grain.
Ron
B. Franklin 1759
Old 08-19-2015, 07:52 AM   #6
Property Mgt/Maint
I agree Ron it is wicking from somewhere, but what explains the top?
Cat?
Old 08-19-2015, 08:26 AM   #7
Retired Moderator
Rewards Points: 7,174
Fog --condensation---where are you?
Old 08-19-2015, 09:07 AM   #8
Cat?
The boards have two ends. I can't see how the wood on top is related to the vertical boards.
Ron
B. Franklin 1759
Old 08-19-2015, 05:54 PM   #9
Property Mgt/Maint
Ron I was referring to the stain on the top. The bottom row of stains sure looks like wicking from something wet. But the stains on top are from something else. Maybe condensation like Mike suggested.
Originally I was curious if the upper and lower boards were wet treated lumber, and the moisture was transferring into the vertical fence boards, but the OP clarified that they were not.
Mysterious Yellow How Water in Tub only heyjoe91 Plumbing 11 10-22-2013 04:23 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 02:37 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 02:53 PM
