Rainbird Check Valve Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rjniles
Old 08-09-2016, 08:30 PM   #1
Rewards Points: 378
Rainbird Check Valve question
I have a few pop-up rainbird heads that need a check valve installed.
Do I need a new check valve sprinkler head or is there a type of nozzle that I can install to stop the run off?
I just don't want to have to dig them up.
Alumifab is offline   Reply With Quote
Old 08-09-2016, 08:41 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Re: Rainbird Check Valve question
Why would you need a check valve for a sprinkler head?
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 08-09-2016, 08:45 PM   #3
Rewards Points: 378
I have 3 pop-up sprinkler heads at the bottom of a slope and when the zone is over the nozzles stay up and the water continues to drain out wasting water.
Old 08-09-2016, 08:51 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
How do you think a check valve would stop that?
Old 08-09-2016, 08:56 PM   #5
Rewards Points: 378
A certified irrigation specialist came out to fix a leak and he suggested that I get some of those.
What would be your recommendation?
Old 08-09-2016, 09:10 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
It will only drain the amount of water in the line past the zone valve. If it keeps draining you need to replace or rebuild the zone valve. Certified irrigation specialist is a bull ****ter.
david86camaro likes this.
Old 08-10-2016, 05:01 AM   #7
Rewards Points: 378
That's correct.
I would like to stop the water from the zone value to the sprinkler head, what's wrong with that?
It's not a lot of water, but it's wasteful.
He didn't try to sell me that, he just suggested it.
I'd rather spend $2 on a check valve instead of $12 on a zone valve.
Old 08-10-2016, 05:17 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
If a check valve will stop the water after the zone valve closes it will also stop the water when the valve is open.
Old 08-10-2016, 06:08 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Have to admit I am wrong on this. Here is what you need,
http://www.rainbird.com/homeowner/pr...ys/1800SAM.htm
Old 08-10-2016, 09:47 AM   #10
Rewards Points: 378
Thank you for actually doing some research instead of continuing to pontificate.
I appreciate it.
Is a check valve required on a sewage ejector pump? crankcase Plumbing 4 11-10-2013 10:09 AM
weeping tile check valve? mae-ling Plumbing 6 01-11-2013 10:08 PM
Husky/CH Compressor check valve question EdPDX Tools 7 10-02-2012 04:37 PM
Check Valve Choices for Sump Pumps jpepe3691 Plumbing 0 02-13-2012 01:37 AM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 07:42 AM
