Rain Water Off Roof. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Guap0_
  • 1 Post By Oso954
Old 06-01-2018, 05:51 PM   #1
HWU
Rewards Points: 62
Rain water off roof.
Last year I had the whole yard landscaped. They did a great job. I also had them bury the downspouts to drain out into the yard. We sent them out 20ft with 3" PVC. This is working quite well...greenest grass in the neighborhood, little did I know I would have to cut every other day...with this wet spring! LOL. Question is...I would like to "Y" off of the existing pipe we laid to reach a few areas that are not receiving the natural flow. Can I ...or should I downsize the pipe out from the "Y" to 2 inch? Would that create a little more pressure to allow it to drain faster? Any thought would be greatly appreciated! Thanks Ra
HWU is offline   Reply With Quote
Old 06-01-2018, 06:24 PM   #2
Guapo
Rewards Points: 11,950
Re: Rain water off roof.
Any of that is doable. It can't hurt anything. However, you may need to cut the grass daily.
Nealtw likes this.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
HWU (06-03-2018)
Old 06-01-2018, 08:10 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,156
No good deed goes unpunished.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
HWU (06-03-2018)
Old 06-02-2018, 09:54 AM   #4
Oso954's Avatar
Rewards Points: 1,946
Downsizing the pipe does not increase pressure.
The only way it would is to have so much flow it exceeds the total capacity of both pipes. Once the water backs up above the Y, the head pressure would increase.
HWU likes this.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
HWU (06-03-2018)
Old 06-02-2018, 10:23 AM   #5
Rewards Points: 6,062
Hi HWU, looks like you are in a cold climate. Buried drain lines can have ice issues and ultimately freeze solid and break, seen several. Even when draining into a pit a trickle of water through a below freezing pipe will layer up until solid. Hay bails or other on top of the ground in fall through winter might help.
Bud
Bud9051 is online now   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
HWU (06-03-2018)
Old 06-03-2018, 02:55 AM   #6
HWU
Rewards Points: 62
Bud, that was the first concern (freezing) when we did this on a previous house about 20 years ago. We never had a problem so I went ahead and did it again on this house. The grade away from the house is pretty good so it drains quite well. I just thought about reaching a few areas that are not getting the extra water off the roof.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Rain water collection system ChrisDIY Landscaping & Lawn Care 7 08-17-2010 03:35 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
