Railroad Ties - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-24-2017, 05:29 PM   #1
Rewards Points: 312
Railroad Ties
Looking to set a row of up to 3 ties high, 40 to 50 ft long to create another tiered look to our backyard mountain. Will eventually have ground cover cascade over the ties. What is the best way to anchor them so they remain upright, and attached to each other?
KPDMinc is online now   Reply With Quote
Old 05-24-2017, 06:34 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Railroad Ties
Predrill and then rebars or lengths of conduit works for me. For the first row.
Big honking spiral nails after that. Also predrilled.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-24-2017, 07:23 PM   #3
Oso954's Avatar
Rewards Points: 2,002
Re: Railroad Ties
When they rot or you otherwise want to dipose of them, they are considered as Treated Wood Waste. In Calif, they have to go to either a landfill that has a composite-lined section, or a hazardous waste landfill.
Not every landfill accepts them.
When I factor in the disposal hassle of hauling them away (about 60 miles for me), I would opt for non-wood options.
Oso954 is online now   Reply With Quote
Old 05-25-2017, 03:13 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,228
Re: Railroad Ties
Not a fan of ties, but a follow-up to your reply to the OP's question, I've always used rebar then spiral spikes. Would conduit be strong enough?
He also might try a half-lap joint with a rebar/spike driven through (always pre-drilled) to keep rows aligned.
lenaitch is offline   Reply With Quote
Old 05-25-2017, 03:49 PM   #5
Rewards Points: 2,378
Re: Railroad Ties
If I read this right, this will be a retaining wall. If so, best go into this with eyes open. If not done right, the fix of the failure could be discouraging and expensive.
Google railroad tie retaining wall deadman and read a bit. Example pages:
https://www.familyhandyman.com/lands...onger/view-all
bob22 is offline   Reply With Quote
Old 05-25-2017, 05:26 PM   #6
Rewards Points: 17,914
Re: Railroad Ties
There's a reason all these old ties are available, they have already started to rot out so they were removed and replaced with new ones.
They also stink.
Use pressure treated 6 X 6's instead.
Best way is to predrill and use at least 2' long rebar, cut and notch the overlaps and make sure the first row sits level, Offset the laps on the next row and notch the overlaps and use flat head ledger Loc screws.
Old 05-25-2017, 07:19 PM   #7
Usually Confused
lenaitch's Avatar
Re: Railroad Ties
I totally agree with all of the negatives regarding railway ties (unless you can legally source new ones, then they just stink more), plus they are murder on saw blades/chains, but I didn't want to dis the OP's project - it's his wall, not mine.
It has always been my understanding and practice that a deadman isn't necessary for 3 rows and under, but I suppose they can't hurt.
Old 05-25-2017, 09:09 PM   #8
jlhaslip's Avatar
Rewards Points: 708
Re: Railroad Ties
Agreed. That's why I did not mention them.
I have built retaining walls using 8 x 8 Timbers c/w deadmen and they are a ton of extra work.
Old 05-25-2017, 09:36 PM   #9
kwikfishron's Avatar
Rewards Points: 372
Re: Railroad Ties
Deadman returns are mandatory when building a timber retaining wall.
kwikfishron is online now   Reply With Quote
Property has barn built of railroad ties Victoria-nola General DIY Discussions 18 08-17-2015 06:15 PM
Raising Rafter Ties builditbig Building & Construction 2 03-04-2014 12:48 AM
Railroad Ties Dining Table sundh Carpentry 14 09-13-2012 12:55 PM
Pavers over railroad ties ejdonnelly21 Landscaping & Lawn Care 3 01-29-2012 07:50 PM
Railroad Ties Wall & Black Widow Spiders Dona Pest Control 4 09-06-2008 04:04 PM
