Quicksand Used As Fill - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-04-2015, 06:55 PM   #1
Super Moderator
joed's Avatar
Rewards Points: 23,776
Quicksand used as fill
I had a new sewage holding tank installed last fall. They brought in some fill to level everything out. In some places it was 2-3 feet thick. Problem is I think this stuff was quicksand. I can take a 2x4 and push it in until I hit the original clay bottom 2 feet down. I even tried walking on it in bare feet and sank up to my knees. It was kind of funny as didn't expect that level of softness. It looked like nice sandy stuff when they brought it and it was dry.
The question I have is, does it need to be removed or will it solidify if I cap it with 3-4 inches of better soil and plant grass? Do to winter settling I need more soil brought in anyway.
Old 05-15-2015, 02:43 PM   #2
Rewards Points: 8
If it has a clay bottom and doesn't drain it may stay soft. Is it saturated with water? I wouldn't put anything on top of it until it solidifies.
tretech is offline   Reply With Quote
Old 05-15-2015, 03:02 PM   #3
Rewards Points: 144
I would say you're only asking for problems by using it .even if you give it the time to solidify it will not be a good base for anything.
mako1 is offline   Reply With Quote
Old 05-15-2015, 04:01 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,..... How much material ya bringin' in,..??
What sorta Equipment is gonna be involved,...
Rather than exportin' the sand, it can be mixed into the clay, 'n soils,....
Sounds like the sub-grades shoulda be graded, Before it was filled, insteada just fillin' the holes,.....
Old 05-15-2015, 04:40 PM   #5
Rewards Points: 1,510
Fill a pint or quart jar about 2/3 full of the sand in question and top it off with water until the jar is full. Shake vigorously for a few minutes, leave set over night then see what you have.
The sample may need to be taken to a soils engineer to determine what you have.
SeniorSitizen is offline   Reply With Quote
Old 05-15-2015, 10:59 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,654
Quick sand is basically round where regular sand has jagged edges that will catch on each other.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Fix'n it (05-16-2015)
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 07:03 AM
Toilet wont fill on its own fixitwoman Plumbing 2 10-18-2011 07:11 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
