Quick Question About Fertilizing - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-13-2017, 01:36 PM   #1
Rewards Points: 191
quick question about fertilizing
location - southern CT
grass types - blend of rye fescue and kentucky blue grass
i will be core aerating and slit seeding this weekend and i want to know what i should fertilize with? i am add new grass in a few small spots and that will get starter fertizlier. i am just trying to figure out what the ideal fertilizer will be to best help these new blades of grass get the best root system over winter.
i have not fertilized since around early june.
rygar is offline   Reply With Quote
Old 09-13-2017, 10:09 PM   #2
Msradell's Avatar
Rewards Points: 824
Re: quick question about fertilizing
The type and amount of fertilizer required varies significantly based on what your soil needs. The 1st thing you should do is take a soil sample and have it analyzed. That will tell you the basic requirements your soil needs such as lime etc. I should also give you the recommended rate and formulation for fertilizer. Especially in the fall you don't want a fertilizer with a very high nitrogen level because that just encourages growth of the aboveground portion of the grass. What you want especially in the fall is to encourage the root system to develop.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 09-13-2017, 11:43 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Pick one with a high last number for Fall application. Good for the roots.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Fastening 1x4 to vinyl arbor post - quick question harpua728 Carpentry 18 08-16-2017 11:30 AM
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 05:03 AM
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 05:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 12:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 12:18 AM
