Question For Small Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2017, 02:05 PM   #1
Rewards Points: 26
question for small retaining wall
I have a deck that sticks out adjacent to a shallow slope. Not only does the ground outside the deck slope down as the deck goes out, but the ground under the deck itself is even lower--I wish I could get a lot of fill in there, but doing so would be a nightmare.
So, I have a decent drop-off in the ground where it goes under the deck. I'd like to shore this up a bit, especially so I can build up the ground a bit and cover over an ugly opening.
A picture of the area is below. The main spot that needs a retaining wall is about 9-11 feet long, depending on how I approach it. The tricky part is that I basically need the wall just under the deck, which makes certain steps (e.g., hammering in rebar) all but impossible.
One thought I had was to get 6x6s and attach a couple to the two pilings you can see in the picture, which are about 9' apart, using the pilings as a brace to keep the wall up. I don't need much height--two 6x6s at most, even with the bottom 6x6 half-buried. I'd probably need another piece angling to the left, to raise up that end, too. From how I figure it, the wall only has to come up about 5-6" from the lowest point of ground level.
FWIW, I also have a load of those hunks of concrete you can see in the shot, under the deck (leftover from an old driveway demolition, years ago); I was wondering if I could cement those together into a wall.
At the far left of the shot you can just see a raised planter; I'd have just enough room to stick the 6x6 between it and that piling, but any attachment to the piling would have to come in from behind/to the sides.
I don't need to do anything to the right of the piling in the foreground.
Looks don't matter here--no one's really ever going to see the wall. How should I approach this?
Scott_R is offline   Reply With Quote
Old 06-20-2017, 05:30 PM   #2
Rewards Points: 300
Re: question for small retaining wall
I guess the question is why? you mention you want to cover an ugly opening, then later say looks dont matter since no one will see it... just confused is all...
KPDMinc is offline   Reply With Quote
Old 06-20-2017, 05:50 PM   #3
Rewards Points: 26
The retaining wall, because it will only be facing under the deck, will be invisible. The opening in the side of/under the deck is not.
Old 06-20-2017, 05:55 PM   #4
Rewards Points: 300
why not just put a skirt around the opening? or use those stack stones on a bed of gravel?
Old 06-20-2017, 06:33 PM   #5
Rewards Points: 26
Because of the other reason I gave for a wall: a decent drop-off that needs to be shored up. I called it a retaining wall because it's not there to hide the opening but to prevent soil loss.
Wood retaining wall question.... acarsme Landscaping & Lawn Care 1 07-29-2016 05:50 AM
Help with retaining wall mold problems -- running out of ideas and in need of help! gottalearn Concrete, Stone & Masonry 17 11-03-2014 06:34 AM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
