PVC Pipes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 09:38 PM   #1
PVC pipes
I feel that I am a handy guy know how to do some things but for some reason I am having trouble keeping my PCV pipes guled together. I have use the purple primer and the hot glue then in 6 mos to 1 year the weld opens up. I have a lot a line pressure becasue I am comming directly off of my meter. Does any one have a answer for me?
pcv paul is offline   Reply With Quote
Old 06-24-2009, 10:33 PM   #2
Kap
Mowing my life away.
Is this residential? i can't imagine your pressure being more than 60-80 psi.
Hot glue? Never heard that term in relation to PVC.
Primer both pieces and apply pvc cement to both surfaces to be glued together. If possible, twist the two pieces 90 degrees immediately after gluing together.
You should hold them together for 15 seconds or so for the glue to grab because the pieces can push apart when first glued.
Kap is offline   Reply With Quote
Old 06-24-2009, 10:47 PM   #3
This house & my last house I have had 85 psi
I couldn't leave hoses turned on very long w/sprayer attachmanet on the end (in off position). The hose would burst
But pipes inside were copper pipes for water, no lawn stuff
I do have CPVC at this house - no problems
Usually as long as it is full inserted & twisted you are fine as Kap said
Old 06-25-2009, 12:25 AM   #4
Kap
The pipes should be able to take that and more.
I wonder...is it sched 40 or 200?
What part of the country/world are you in, paul? Do your pipes freeze? Is it only breaking at the joints?
Old 06-25-2009, 06:41 PM   #5
Don't know it all, yet!
HMMM
I think we're going to learn something here.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-16-2009 12:10 AM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
