Pump Sprayer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By Msradell
  • 1 Post By DoomsDave
Old 10-09-2018, 09:00 PM   #1
Rewards Points: 48
pump sprayer
I have an old gallon pump sprayer that I want to start using. I don't remember what was in it but it does not smell too good. What can I used to clean it out? I will need to replace the hose and it has no nozzle. Any suggestions?
tramp is offline   Reply With Quote
Old 10-09-2018, 10:29 PM   #2
Msradell's Avatar
Rewards Points: 912
Re: pump sprayer
Unless the sprayer has a stainless steel tank it's probably not worth fixing it. They're not that expensive, just to buy a new one. Order ones have a tendency to have seals etc. dry out and never work as well as they did when they were new.
Bondo and joecaption like this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 10-10-2018, 11:32 AM   #3
Rewards Points: 48
Re: pump sprayer
What I want to do is keep it for a spare. It is a heavy duty plastic sprayer. Nothing wrong with it. If my other plastic sprayer should break, I can transfer the hose and nozzle to this one. I don't know if I had grass killer in it or diesel to kill grass.
Old 10-11-2018, 08:56 AM   #4
retired painter
Rewards Points: 822
Re: pump sprayer
I'd pour it out where you don't want grass to grow and then rinse it well. Store it so the water will drain out. I always leave the cap/pump off of mine when not in use.
mark sr is offline   Reply With Quote
Old 12-06-2018, 10:11 AM   #5
DoomsDave's Avatar
Rewards Points: 7,066
Re: pump sprayer
Dump out that old stuff, and clean with some soap and water, a few times, then rinse.
You can get sprayer overhaul kits for seals from hardware stores; they run about $14; they'll have a variety of seals meant to fix a variety of sprayers. I have a Spray Doc from the 1980s I've had for 32 years and it still works.
Gymschu likes this.
DoomsDave is offline   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 09:07 PM
Sump pump check valve, on pump or spliced in pipe? ponch37300 Plumbing 1 06-18-2016 01:26 PM
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 09:43 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
