Is This PT? (Pressure Treated Wood) - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-25-2015, 02:44 AM   #1
l008com's Avatar
Rewards Points: 620
Send a message via AIM to l008com
Question
Is this PT? (Pressure Treated Wood)
I dug up these old landscaping ties from the front of my house. Even though you'd think they would be PT, they were so rotten, I thought they had to be regular wood. I let them try out for a long time and today I cut one up to use as firewood. As bad as they look on the outside, they look really good on the inside..... they don't look rotten at all inside, and they look like PT. What do you think?
And yet from the outside, they look like rotten, junk, non-pt crap:
l008com is offline   Reply With Quote
Old 07-25-2015, 05:56 AM   #2
Retired Moderator
Rewards Points: 7,174
Yep--sure looks like PT from here---
Old 07-25-2015, 07:13 AM   #3
Rewards Points: 17,912
Read the label on new pressure treated landscape timbers.
It's reads not rated for below ground use.
If I have build a raised bed I use 4 X 4's 4 X 6's or 6 X 6's there rated for below ground use.
Makes no since there not below ground rated, just the way it is.
There nothing more then the core of the logs left over from making plywood, that's why there all 8' long.
Old 07-25-2015, 07:24 AM   #4
Rewards Points: 1,506
As much as we would like the term " pressure treated " to prevent rot in wood we buy today that isn't what PT is for but to repel insect damage.
Our society won't allow anything that would even come close to preventing wood rot.
Old 07-25-2015, 07:48 AM   #5
l008com's Avatar
Rewards Points: 620
In defense of that societal stance: railroad ties are pretty resistant to rotting and they are partially underground (though in gravel not dirt so that probably doesn't count). When they rip up the tracks to build a bike route after the line goes out of service, the soil is filled with arsenic and other chemicals that leach out of the ties.
Overall trains are very good for the environment but their negativity gets condensed into small areas and those areas aren't great places to be.
Old 07-25-2015, 09:03 AM   #6
Rewards Points: 7,540
Those are not real railroad ties. Those are sold at the big box stores ---made to kinda look like ties. You wouldn't be able to wrap your hand halfway around a real railroad tie. Probably pressure treated pine.
SPS-1 is online now   Reply With Quote
Old 07-25-2015, 10:31 AM   #7
Civil Engineer
Rewards Points: 5,246
Perhaps the OPS is wondering if the wood is safe to burn? If it is PT, should not be burned, as it is full of metals like arsenic, copper, maybe chromium.
Old 07-25-2015, 02:02 PM   #8
l008com's Avatar
Rewards Points: 620
I know what I have isn't real railroad ties, I was just referring to railroad ties in regards to the idea that you don't want truly rot-proof wood just laying around your yard.
The Following User Says Thank You to l008com For This Useful Post:
oh'mike (07-25-2015)
Pressure treated wood in enclosed space estarski Building & Construction 2 05-26-2015 11:25 PM
How important is pressure treated wood? lae26 Building & Construction 22 03-16-2013 12:25 AM
pressure treated wood project -- acceptable quality? bunchofquestion Building & Construction 6 11-09-2011 09:17 PM
Pressure treated wood? sharp Building & Construction 5 04-13-2010 07:50 AM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 10:02 PM
