Proper Way To Install Runoff Trenches Around Driveway? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bondo
Old 05-31-2017, 12:55 PM   #1
On the Road Less Traveled
The Jeep Driver's Avatar
Rewards Points: 127
Question
Proper Way to Install Runoff Trenches Around Driveway?
The short of it; I need to how how to install a runoff trench next to my driveway correctly. I searched around the internet and read a lot of different ideas and opinions. This link is an example of what I need to do... a small trench back-filled with sand and stone. I have read not to use landscape fabric as in the example, but to use non-woven drain field fabric. The example states to line the sides with the fabric, but not the bottom or the top. The bottom not being lined I understand, but how do I keep dirt (silt) from running off the yard and just filling the trench?
And the why of it: I had to have 12 helical piers installed around the garage in September of 2016. There was a raised flower-bed... well there is a picture linked below of the layout, I am getting runoff from the yard, into the driveway, which then runs into the drain in front of the garage, and the mud/silt from the runoff has now clogged the drain.
Thanks in advance for any advice!
(sorry I wasn't about to post the pic in-line here, photobucket seems to be gone, so I had to use OneDrive)
Driveway layout picture.
The Jeep Driver is offline   Reply With Quote
Old 05-31-2017, 04:31 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Proper Way to Install Runoff Trenches Around Driveway?
Ayuh,.... How much elevation drop ya got from where the raised bed was at the corner of the garage/ driveway, down to the street,..??
Not the answer yer lookin' for, but with the limited pictures, what I'd do is,....
Dig a swale from the corner at the raised bed, to the street, 'n get grass growin' in it,...
A swale is a gentle slopin' trench, that's walkable, mowable, 'n possibly driveable,....
The rock filled trench yer lookin' at ain't compatible with any of the above,...
The Following User Says Thank You to Bondo For This Useful Post:
The Jeep Driver (06-01-2017)
Old 05-31-2017, 07:21 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,180
I agree with Bondo that the solutions available to you will depend on the grade available to you. It's hard to tell but from the perspective of the photo leading off to the horizon it doesn't look like much. If the ruling grade is across the driveway (evidenced by the fact that water currently runs that way) and there isn't sufficient grade in the opposite direction to draw water away, there's not much you can do.
I like the idea of a grass swale. Even if it is just a slight grade and most of the water soaks into the soil, the same thing is accomplished.
If you can re-establish grass, etc. from last year's construction, will the silt problem not be solved?
lenaitch is online now   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Old 06-01-2017, 04:51 PM   #4
Rewards Points: 127
Good point, the grass should stop it.
Both the runoff trench and the swale will move water toward the street, why is the swale the better option?
I'll get some better pictures and elevation measurements as soon as I can. Thank you for the replies!
Old 06-01-2017, 07:12 PM   #5
Bondo's Avatar
Ayuh,.... Answered that,...
With a swale, it's usable space, with a rock filled trench,... It Ain't,....
lenaitch likes this.
Tags
driveways , rainwater , runoff trenches
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 08:42 AM
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 08:16 AM
