Proper Paver Footing - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 11:19 AM   #1
Lightbulb
We are getting bids on paver sidewalks and patio. Most of them use sand and the one company uses 1B stone and does not use sand because they say the ants drag it away and the rain washes the sand away. They seemed very knowledgeable, but I am so unsure of what to do. Everyone says there way is the best way. Any thoughts?
Diannj is offline   Reply With Quote
Old 05-14-2012, 11:41 AM   #2
concretemasonry's Avatar
Rewards Points: 2,716
I assume you are using the most common type of pavers - interlocking concrete pavers. They are set in a 1" sand setting bed over a compacted base.
Just look at the installation of the ICPI (Interlocking Concrete Paver Institute) on icpi.org. - If you are using the larger, thinner pavers (stepping stones, etc.), then you are in a different unstructured world without formal methods and materials.
The ICPI has specifications on materials and installation in addition to certifying paver contractors.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Ravenworks (05-16-2012)
Old 05-16-2012, 02:45 AM   #3
My patio has a plate compacted 8" gravel base with a layer of geo grid in the middle of it. (I live in the mid west where freeze/thaw cycles can mess with a patio) On top of the gravel is a .5" layer of sand that creates a level surface to place the pavers. After all of the pavers are placed I swept in poly sand and compated it all down with a plate compactor. After compacting I added water to harden the sand. Poly sand will protect against ants, weeds and will not wash away from the rain. Contractors in my area typically quote between $9.50-$14 per square foot for installation and then around $17/face foot for a retaining wall. Good luck
thrice910 is offline   Reply With Quote
The Following User Says Thank You to thrice910 For This Useful Post:
Old 05-16-2012, 04:07 AM   #4
Ravenworks's Avatar
Poly sand is the ticket,it stays put!
Ravenworks is offline   Reply With Quote
Old 05-16-2012, 06:05 AM   #5
I have never seen polymeric sand used on a serious paver installation with high loads in jobs such as streets, roads, airport taxiways or industrial site (up to 25 acres). You could use it in a casual job like a patio, even though most weeds are from airborne seeds that can take root anywhere. It does not add any strength if you have a proper base.
Dick
How to pour a replacement piece of footing? Homerepairguy Concrete, Stone & Masonry 2 02-29-2012 12:51 PM
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 01:39 PM
Proper concrete for footing and stem wall JayG Building & Construction 18 03-05-2010 01:53 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 01:50 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
