Preventing Water Hammering - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-06-2016, 09:59 PM   #1
Rewards Points: 49
We have an irrigation system with 8 valves in the manifold. Every morning when the sprinklers run, we get woken up by loud vibrations from water hammering. Is there any way to prevent this?
Cultcab is offline   Reply With Quote
Old 04-06-2016, 10:14 PM   #2
Rewards Points: 18,074
Re: Preventing Water Hammering
Add a water hammer or make your own.
https://www.google.com/webhp?sourcei...depot&tbm=shop
Old 04-06-2016, 11:00 PM   #3
Rewards Points: 49
Where would I install this?
We had a pool built several years ago and we had the same water hammering with the autofill. They placed an arrestor on the line right where the autofill branched off of the main line and it worked great.
I have a 1" water line coming into the manifold - do I need to place the arrestor on that line before it enters the manifold?
Old 04-16-2016, 09:23 PM   #4
Rewards Points: 2,800
Ideally the water hammer arrestor is placed as close as possible to the valve or other component that is generating the shock wave such as the rapidly closing, or worse yet, chattering and defective, valve.
But you may find that one arrestor on or just before the manifold works okay avoiding the need to have eight arrestors, one on each of the lines coming off of the manifold.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 09:13 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
