Prepping For Sod - Help! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2017, 04:37 PM   #1
Prepping for Sod - Help!
I am trying to prep my yard for sod and live in an area that has a sandy and clay mixture of soil. We live at 7500 feet. I am using a Rototiller to break down the soil and mixing in a little bit of mulch to give it some nutrients, will this work? I'm now rethinking whether or not the mulch was a good idea. I had some leftover didn't want to spend extra money on top soil or compost. The mulch is getting broken down by the Rototiller into small pieces and mixing with the soil. I then plan to level it out and lay sod on top of this. Any feedback or help with this would be appreciated.
KTlady is offline   Reply With Quote
Old 06-18-2017, 04:59 PM   #2
Rewards Points: 6,172
Re: Prepping for Sod - Help!
Welcome to the forum.
In NJ we saw a lot of sod installed over sandy soil, no clay, and over watering was bad/ Best place to get advice would be the people you are buying from or the sod farm they are buying from. Typically they have an interest in your success.
Bud
Bud9051 is offline   Reply With Quote
Old 06-18-2017, 05:02 PM   #3
RRH
Rewards Points: 1,336
Yes, the mulch was not a good idea. But if mixed in well would not worry to much. Not a lot to do about it now.
Compost or manure would have been so much better.
Wood after composed adds organic matter.
The mulch will decompose BUT as it does it will puts off a gas that can kill the grass.
But will take a fair amount to make a difference
RRH is offline   Reply With Quote
Old 06-18-2017, 05:05 PM   #4
RRH
Also take a PH test. Now is a good time to add lime if your PH is low.
Over watering can happen. But the problem the majority of the time is not enough.
Old 06-18-2017, 05:09 PM   #5
I hear a lot about over watering and the acidity of the soil due to pine needles. Should I scrape the top layer off and put soil? I'm inclined to leave it and joe for the best. ??
Old 06-18-2017, 05:13 PM   #6
Hope for the best *fingers crossed*
And thank you both.
Old 06-18-2017, 06:41 PM   #7
Rewards Points: 1,042
Best to do a ph test, soil could be alkaline, in that case use composted cow manure.
Canarywood1 is offline   Reply With Quote
Old 06-19-2017, 12:10 PM   #8
Rewards Points: 2,378
Always test soil and add what is needed, not guessed at.
Local ag extension office many times does it for free or at a very low cost.
bob22 is offline   Reply With Quote
Old 06-19-2017, 01:03 PM   #9
Rewards Points: 4,170
Decaying wood can lead to mushrooms. Given that the pieces will be small enough that digging them out would not be feasible, be prepared to kick the tops off frequently.
One more vote for a soil test.
stick\shift is offline   Reply With Quote
Prepping Concrete For Ceramic Tile slappydan Flooring 3 06-28-2014 11:08 PM
Prepping a deck - kinda tricky spaceman spif Painting 14 08-25-2012 07:10 PM
Prepping Concrete Subfloor b1021 Flooring 0 07-31-2012 09:02 AM
Prepping for shower pan questions... ktkelly Plumbing 1 06-12-2012 08:08 PM
prepping for painting on NC home carpenal Painting 13 03-29-2011 11:19 PM
