Power Wash Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By ZTMAN
  • 1 Post By ron45
  • 1 Post By tramp
Old 03-18-2019, 05:35 PM   #1
Rewards Points: 48
Power wash driveway
I am power washing my driveway to get the mildew off. After I power wash it, what can I spray on it to keep the mildew off? At least for a while anyway. There was a kid power washing the driveway at the vacant house next to me and I was going to talk to him to see what he used but when I got back from my road trip, he was gone. That driveway came out white like new concrete.
I could be in the wrong forum.
tramp is offline   Reply With Quote
Old 03-18-2019, 05:38 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Re: Power wash driveway
Not much is going to keep mildew off of horizontal concrete.
Bet bet it to clean it when it gets dirty.
Old 03-18-2019, 06:07 PM   #3
ZTMAN's Avatar
Rewards Points: 342
Try Wet N' Forget.
Works for my brick walkway, patio, and vinyl siding
Msradell likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 03-18-2019, 06:32 PM   #4
Rewards Points: 48
Originally Posted by ZTMAN View Post
Try Wet N' Forget.
Thanks, I was thinking about that just a couple of minutes ago. After I power wash, I will spray Wet N' Forget on it and see how that works.
Old 03-18-2019, 06:40 PM   #5
ZTMAN's Avatar
Rewards Points: 342
I have not found a better product. I buy it in the six gallon concentrate, use a pump sprayer and call it done.
I have a dedicated pump sprayer for the product since I marked the mix ratio right on the pumper. That way don't have to measure each time you apply.
Old 03-18-2019, 10:02 PM   #6
Msradell's Avatar
Rewards Points: 824
Just recently, I saw that they also have it available in a hose end applicator. Certainly would make it much easier and faster to apply.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 03-19-2019, 06:39 AM   #7
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,218
Which raises the next question:
Is a pressure washer required to rinse it off. I say no.
There are very few things that will be improved by pressure washing.
Old 03-19-2019, 06:55 AM   #8
Most folks use way too much pressure when using a pressure washer.
These new rotating heads tend to make faster work of this bulk type work and control the output pressures at the nozzle heads to prevent much damage to the substrates.
Old 03-19-2019, 10:51 AM   #9
Rewards Points: 48
In my case, a pressure washer was required. The mildew was extremely bad and caked on. Just rinsing it off would not have worked. Taking one section at a time and the cement looks almost new. Will spray Wet N Forget when I am finished. Hopefully that will last a while.
Old 03-26-2019, 08:57 AM   #10
Rewards Points: 4,430
Also.
This really works.
Used it on my house last year.
Now this year I can see where I missed
Put in the power washer then rinse with a regular hose.
I would highly suggest the set up that Windows on Wash's video showed. It works far better then just using the wand, no streaks and cut marks. Rinse first to allow the water to help.
Windows on Wash likes this.
ron45 is online now   Reply With Quote
Old 03-26-2019, 01:57 PM   #11
Rewards Points: 48
I finished power washing my driveway, sidewalk and patio. As you can see by the picture the before and after is quite a difference. I have sprayed wet & forget after the power wash.
ZTMAN likes this.
Old 03-26-2019, 06:08 PM   #12
ZTMAN's Avatar
Rewards Points: 342
Looks good
No power to Christmas light outlet - appears to be homerun rdiggidy Electrical 11 12-11-2018 04:32 PM
Compressors making the power go out? Kantaris Electrical 12 08-02-2018 09:59 PM
Two 120v power sources, automatic switch/relay NCmountainCabin Electrical 12 06-25-2018 08:24 AM
California Home Power limits? (5+ computers in 1 room) jazzman170 Electrical 34 10-02-2014 10:37 AM
Power Wash Stone House? sweaty General DIY Discussions 1 08-06-2008 07:48 AM
