Poulan Blower / Vac Won't Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-23-2016, 04:31 PM   #1
Another DIY Zombie
Rewards Points: 264
Poulan blower / vac won't start
I am at my wits end.
This is the BVM200VS model. About 9 years old. Just replaced carb, plug, fuel lines, fuel. It will only start on full choke and will run about 10 seconds, then die. I notice when pushing in the fuel primer, it stays in, then very slowly pops out. In order to prime bulb 3x, it takes about 4-5 minutes. Have removed muffler and that is quite clear. I am ready to toss it and buy electric.
javan is offline   Reply With Quote
Old 05-23-2016, 04:40 PM   #2
Rewards Points: 17,912
Re: Poulan blower / vac won't start
Change the fuel filter in the tank?
Old 05-23-2016, 06:29 PM   #3
Another DIY Zombie
Rewards Points: 264
Yes, replaced fuel filter too. Symptoms first started out as only running for about 5 seconds, with good throttle response. Then I noticed fuel lines were rotten, so I bought new fuel lines, filter and carb. One note. The new primer stays pushed in for about 30-40 seconds. I tried the old primer and it goes in / out easily, but it is not really moving gas well. Appears to be a lot of air, but I have no idea where from.
Old 05-23-2016, 06:33 PM   #4
Another DIY Zombie
Rewards Points: 264
I even tried review fuel filter and priming and still it has tons of air.
Old 05-24-2016, 05:27 AM   #5
Another DIY Zombie
Rewards Points: 264
sorry, meant to say that I tried priming with the filter removed and still it does not seem to prime, bulb just stays pushed in. Have also tried the old primer bulb, that one will pop back out and quickly, but still is not moving gas. Now thinking either a fuel line leak, or clogged carb (yet it's brand new and has only seen new gas with new filter).
Old 05-24-2016, 07:08 AM   #6
Rewards Points: 392
Could be the gas tank cap vent is plugged. Carefully, try running it with the cap cracked slightly to see if the problem goes away.
rustyjames is offline   Reply With Quote
Old 05-24-2016, 08:26 AM   #7
Another DIY Zombie
Rewards Points: 264
possibly, but still have the issue of it not priming properly. I tried priming with cap on and off.
Blower motor not working Jrepou HVAC 4 05-10-2016 04:28 PM
Replaced Blower Motor; It worked, then stopped. Help ericvon HVAC 12 03-30-2015 04:25 PM
Carrier Blower Wheel Failures AzJeepguy HVAC 8 08-03-2014 03:09 PM
What causes blower slow start up on new motor justplumducky HVAC 1 02-21-2014 08:18 AM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
