Potential Problem (root Girdling) With Citrus Tree Planting? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-22-2019, 04:31 PM   #1
Rewards Points: 34
Potential problem (root girdling) with citrus tree planting?
I live in Sacramento, CA area. In April 2018, I purchased two dwarf citrus trees (navel orange, meyer lemon) for planting from our local nursery (5 gal containers). I decided to put the orange tree in the ground and the lemon tree in a planter box. The soil in the ground is 90% rock (the house is situated on a plot which was carved/flattened from the side of a small hill.
For planting the orange tree, I followed most of the basic instructions of planting a new tree. Dug a hole 2-3 times the width of rootball diameter and rootball depth, removed all the rock and replaced with garden soil/compost (50%/50%) mixture, exposed the root flare just slightly above ground level (I think), and kept the mulch a good 1 feet away from the trunk. I have been watering/fertilizing regularly, and the tree looks healthy. Plenty of young fruit which I picked off early to get the tree to concentrate on root/trunk development.
However, I have a concern about the root growth. I notice a root going around the small trunk and what looks like a potential root girdling? I'm attaching some pictures. Is there cause of concern or is this root growth normal? If problem, should I just cut the root that is going out and then back in? Will it kill the young tree? The tree is growing actively so I am not sure.
I'm also attaching pics for the lemon tree and that looks OK. The roots are fanning out in all directions which looks good. Thanks for any opinions.
Pictures are on on this Citrus Tree Pictures
raveon is offline   Reply With Quote
Old 07-22-2019, 04:52 PM   #2
Rewards Points: 2,186
Re: Potential problem (root girdling) with citrus tree planting?
For fruit tree that looks normal to me. that's how they breath. Do not cut any roots.
If anything, I would remove all the mulch, put inch or so 50/50 top soil/compost mix all around the planter box, do not cover the exposed roots at the bottom, then put new mulch down. Just a suggestion and my opinion only. Google and others may disagree.
jmon is offline   Reply With Quote
Old 07-24-2019, 10:33 PM   #3
Rewards Points: 576
You did not say you spread out the roots when planting. If you did...no worries. If you did not, the roots will grow in a circle and that is not good. Did you scarify the sides of the hole when planting ? Hope so...especially in a hard, rocky soil. This permits the tiny new root hairs to get into the soil and spread... I could not open your pics.
Cedrus is offline   Reply With Quote
