Pipe Size Needed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-27-2017, 11:13 AM   #1
Rewards Points: 4
Pipe size needed
Hey Y'all,
I'm really hoping someone can help me here. I have ~5 acres of land with 4 small "drainage ponds" on it. What I'd like to do is set up one gas-powered water pump with a PVC valve manifold intended to choose which pond I'd like to drain (one at time or a combination of them). I can't figure out how to attach an image, so I'll try to explain what's going on.
Pond 1 - 60 feet from pump, straight line, slight slope down to pump.
Pond 2 - 200 feet from pump straight line, slight slope down to pump.
Pond 3 - 300 feet from pump, straight line, slight slope down to pump.
Pond 4 - 570 feet from pump, 45-degree angle near middle of line to pump, slope down to pump.
Let me know what other information I can get. I appreciate your help!!
Jesse
finejob_13 is offline   Reply With Quote
Old 03-27-2017, 11:35 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Pipe size needed
Ayuh,.... Only problem I see is,.....
Pumps will push, but hate to suck,.....
You'd be better off with a portable pump,...
Old 03-27-2017, 12:04 PM   #3
Rewards Points: 4
Thanks for the quick response Bondo, I do appreciate it.
We've been using a portable pump, but it's not user-friendly for the majority of people that are around. The land actually belongs to a volunteer-driven animal sanctuary, and most of our volunteers aren't comfortable with the portable pump. We just received a generous donation of a much larger pump (9HP, ~450 GPM) and I was hoping to be able to use that and make it easy for everyone. It gets very tough during the rainy season in Florida.
I can install a capped T for each line near the valve to prime the pipe before turning the pump on, plus it's a downhill slope for the most part, so I didn't think it would be pulling too awfully hard. What do you think?
Thanks again for your help!
jesse
Old 03-27-2017, 01:46 PM   #4
Bondo's Avatar
Ayuh,.... IF, it's in fact downhill, below each pond, then ya, once ya prime the lines, they should siphon down to the pump,....
In theory, you could plumb 'em all to a manifold at the pump,...
As for the line size, go as big as the pump will hook up too, or bigger,....
Tags
drainage , flow , pipe , pump , size
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Spiral pipe size vs. CFM for AC amakarevic HVAC 15 12-07-2013 10:42 PM
(Louisiana) What size pipe Sewer, Drain and fresh water supply lines cmb7684 Plumbing 0 04-23-2013 05:54 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
