Pipe Size For In Ground Sprinkler System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 06-07-2017, 12:43 PM   #1
Pipe size for in ground sprinkler system
Hey all,
We have a new patio going in along our garage's side right now, and we'd like a pipe run under it and into the garage (where the water tap is). That way, the garden running along the other side of the pathway can have a sprinkler system put in later, without digging up the walkway (we'd just cap the ends for now). Based on charts about GPM and service line size, it looks like we'd need 1" pipe size.
This is Ontario, so all I've read is that poly tube is better for cold winters. Would squishypipe be ok under a walkway though? Plus it being run through a hole in the garage concrete wall?
Any other tips about running it through the wall? We figured going up on an angle to have it right at ground level in the garage but under the walkway outside... is that a bad idea?
Our contractor does only patios, he's not familiar with sprinkler systems and we've dropped all the money we can for the next few years, hence the "finish it later" part, and also hence the not calling a sprinkler professional...
thanks!
parakyl is offline   Reply With Quote
Old 06-07-2017, 10:20 PM   #2
Msradell's Avatar
Rewards Points: 818
Re: Pipe size for in ground sprinkler system
Why not just call up a sprinkler contractor in your area and ask him about what would normally be used. He will know a lot better what's the norm in your area than any of us who don't live there will.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-08-2017, 05:44 PM   #3
Rewards Points: 1,042
One inch is more than enough, 3/4" is what the zones will use.
Canarywood1 is offline   Reply With Quote
Old 06-08-2017, 05:53 PM   #4
Rewards Points: 1,522
Be sure to sleeve it then if you feel changes are necessary it will be much simpler to do than if not sleeved.
Msradell likes this.
Dewinterize sprinkler system - New homeowner Jason7613 Landscaping & Lawn Care 5 04-30-2017 08:25 AM
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
