Pella Sliding Glass Door - Doesnt - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-26-2017, 02:16 PM   #1
Rewards Points: 2
Pella sliding glass door - doesnt
I have a 2001 vintage pella exterior sliding glass door that is binding when sliding. I can't find a model number. It has a 3/8 inch hole about 4" up from the bottom that I thought nigh be the roller adj hole but the screwdriver goes in far beyond the roller assembled. There is also a small SS screw about 1 inch from bottom but I can't see a screwdriver fitting into the hole. None of the pella replacement roller assemblies seem to have a attechment score hole on their end. In Addison someone has stripped the two bracket screws that hind the sliding door in place if it were to jump the tracks . Also the sliding door is on the outside and every Fixit". Video I have see has the moving door on inside. Does anyone know what the thread pattern of the little Phillips screw migh be. Ditto the right rolle assembles? House is in a remote from hardware store area and I don't want to leave door off while I go 100 miles to hardware store.
Thoughts?
Dgarri in NM
Dgarri is offline   Reply With Quote
Old 08-26-2017, 04:02 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,260
Re: Pella sliding glass door - doesnt
When possible, post pictures of the door in its completeness, inside and out, as well as a close up picture of the adjustment holes at the bottom. Generally a #2 phillips screwdriver will adjust the roller.. Sometimes you will need to give the door a little lift since they are so heavy.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Pella Sliding Glass Door Repair/Replace exocet Windows and Doors 12 08-29-2017 08:54 AM
Moisture damage to Pella sliding glass door climbmda Windows and Doors 4 09-20-2016 06:27 PM
Pella Sliding Glass door (Wood) iceman 64 Windows and Doors 1 09-09-2012 12:19 PM
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 12:28 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 11:22 AM
