Paver Stones Or Cement? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 09:41 PM   #1
Rewards Points: 33
Paver stones or cement?
What would be best for my 16x16 patio area? I've haven't done either job before but have done a good amount of DIY home stuff. Sounds like paving stones require a lot more pre-work than concrete. Paver stones may look nicer... concrete and paving stones seem to be about the same price here, maybe the concrete is a little cheaper. We like the looks of both so now I'm down to choosing the one that has the highest chance of being a total success.
I'm starting from my rough grade, new house.
Thanks.
recklessrick is offline   Reply With Quote
Old 06-02-2013, 10:14 PM   #2
747
registered
747's Avatar
Rewards Points: 544
concrete. Just build a form. Paver stones is all about proper prep. Which can be a real pain in the ass. Especially if you don't have all the rite equipment. I have a concrete patio. I like it. I just hit it with the leaf blower to keep it looking nice. Occasionally i hose it down.
747 is offline   Reply With Quote
Old 06-03-2013, 08:54 AM   #3
Too Short? Cut it Again!
It is not a DIY project but look into stamped concrete. Or stained and patterned concrete. Or a combination. Concrete stamps come in hundreds of patterns.
You might also look into the high end rubber pavers used by horse farms and tracks that you can put over concrete. They come in all kinds of colors, patterns and their even rubber pavers that look like cobblestones.
One nice thing about concrete is that, with adequate expansion joints, it will heave as a unit. Not much at all if nicely poured.
Your profile does not indicate where you live. Pavers, if not installed properly can be a real problem in ground freeze environments.
Old 06-03-2013, 12:15 PM   #4
Rewards Points: 33
My bad, I'll have to update that. I'm in central Canada so you could say that there is a bit of ground freeze/thaw
Old 06-03-2013, 03:06 PM   #5
Rewards Points: 1,042
With concrete if it's not properly installed,there's a very good chance it will eventually crack,with pavers if properly installed you avoid that problem,and if you do have a problem they can be reset,not so with concrete.
Canarywood1 is offline   Reply With Quote
Old 06-03-2013, 03:46 PM   #6
Rewards Points: 33
Where I am, concrete ALWAYS cracks. I have a 9 month old, $8700 driveway done by one if the best places in the city and it didn't make the winter/spring cycle without cracking in two places. So I'd expect a patio in my back yard to crack on me... I'm thinking there is more chance of me getting the prep work right (I have access to people who've done concrete work before) with concrete... Cold winters and 100% clay soil, hard on outdoor stuff.
Old 06-04-2013, 11:15 AM   #7
Canada eh? A deck is out of the question? The simulated wood products out these days are amazing. Can't wait to redo my deck and never have to stain again.
Tatertot is offline   Reply With Quote
The Following User Says Thank You to Tatertot For This Useful Post:
Two Knots (06-04-2013)
Old 06-04-2013, 11:44 AM   #8
Rewards Points: 33
I actually just built a deck in the yard using composite boards and aluminum railing. It nice... Not cheap here though. The deck is 6' up so the patio is going to serve as our lower, more private, dining area.
Old 06-04-2013, 12:58 PM   #9
Rewards Points: 254
concrete is easier but if you never have messed with it before it might be hard. For that area you will need a cement truck or a mix on site type of rig and a lot of helpers with wheel barrels.
pwgsx is offline   Reply With Quote
Old 06-04-2013, 01:01 PM   #10
Rewards Points: 33
I'd get a cement truck for sure. A guy at work here has done some cement work, added a 3rd pad to his driveway, patio work so I was going to get him to give me a hand.
paver stones on retaining wall drmax Landscaping & Lawn Care 10 06-04-2013 01:00 AM
will play sand keep paver stones in place? amakarevic Landscaping & Lawn Care 15 09-03-2012 12:28 PM
Better - gravel or paver base for cement slab ? timcsi Building & Construction 1 08-19-2011 09:26 PM
Question regarding Paver Stones driveway sub base krwhite Building & Construction 2 08-18-2011 01:58 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
