Patio Grading Problem? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-26-2019, 10:10 PM   #1
GBunny
Rewards Points: 83
Patio Grading problem?
I had a patio installed 2 years ago. Now there seems to be concrete crumbling off the wall where the patio meets the wall. There is also moss growing there. I do not see water accumulating on top but could this be an indication it is under the patio stones?
GBunny is offline   Reply With Quote
Old 05-26-2019, 10:37 PM   #2
Msradell's Avatar
Rewards Points: 890
Re: Patio Grading problem?
A couple of pictures of the area you are talking about would be very helpful.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-26-2019, 11:09 PM   #3
GBunny
Rewards Points: 83
I do not see any options to attach photos.
Old 05-26-2019, 11:15 PM   #4
GBunny
Rewards Points: 83
There appear to be little bits of concrete or whatever that is and moss growing where the patio meets wall
Old 05-26-2019, 11:38 PM   #5
JUSTA MEMBER
Rewards Points: 72
I have the same answer, as I posted on the other question.
Warranty on the work?
ED
de-nagorg is online now   Reply With Quote
Old 05-27-2019, 12:08 AM   #6
GBunny
Rewards Points: 83
There is no warranty per se but contractor said he would regrade if another contractor thought it was necessary. To me it is obvious he made a mistake. What I need to know is if excessive water under the stones could cause the cement above the patio stones to flake like that?
Old 05-27-2019, 12:31 AM   #7
JUSTA MEMBER
Rewards Points: 72
No.
Flaking soon after installation, is a sign of poor mix, or drying too fast.
Was the work done on a very hot day, temp above 90 degrees? Low humidity that day.
Concrete is a science, and lots of things can be done wrong and cause trouble.
ED
Old 05-27-2019, 12:56 AM   #8
GBunny
Rewards Points: 83
He did not work on concrete. He only laid the gravel and Stones. He did not dig down to lay the base. He only laid gravel on ground to try to save me money. My theory is that water is pooling under patio stones as grade is towards house. I do not see water pooling on top of stones. Yet the concrete on wall keeps flaking. What could be causing that?
Old 05-27-2019, 05:54 AM   #9
JUSTA MEMBER
Rewards Points: 72
How old is the wall portion then?
Flaking shows dryness, not pooling water.
ED
Old 05-27-2019, 09:25 AM   #10
GBunny
Rewards Points: 83
the house was built in 1974. I did not have this problem before the patio was installed. They only area around the house where this is happening is above the patio.
patio awning problem anon125 Building & Construction 10 07-04-2018 09:17 PM
Remedy addition over patio slab bocar Building & Construction 7 01-30-2018 05:30 PM
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 10:40 AM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
