Pathway Fines For Dry Creek Base?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bondo
Old 12-07-2018, 07:08 PM   #1
Rewards Points: 73
Question
Pathway fines for dry creek base??
Hi, I'm adding a dry creek in my front yard...and the typical materials seem to be a pea gravel base, then the decorative rocks on top.
My question is, can I use pathway fines instead of pea gravel?
I only ask because I happened to have a bunch of Blue Pathway Fines left over from some previous flagstones I put in. I certainly realize this is a much finer material than pea gravel -- much of it like sand -- but if it's acceptable, it would certainly be a nice way to use the leftover material.
Thanks for your thoughts.
RinSF is offline   Reply With Quote
Old 12-07-2018, 07:23 PM   #2
retired framer
Rewards Points: 20,402
Re: Pathway fines for dry creek base??
I have walked up a few real ones. They don't usually follow anyone's rules.
Old 12-08-2018, 07:10 AM   #3
retired painter
Rewards Points: 1,776
What type of soil? the finer the initial layer is the more apt it is to get swallowed up by soft soil.
mark sr is offline   Reply With Quote
Old 12-08-2018, 07:15 AM   #4
Rewards Points: 6,997
It's your yard and your choice. I totally agree with:
When using the finer stock I would probably add a layer of landscape fabric before I spread the stones.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 12-08-2018, 09:57 AM   #5
Rewards Points: 73
Thanks for your replies so far, just to respond to questions...
- Yes, it would be landscape fabric, then pea gravel (or path fines), then the decorative rocks.
- The soil here is pretty clay-ish.
So as mentioned, most information seems to recommend pea gravel. I have no idea why, but since they all seem to say this, that's why I didn't know if path fines would be okay or not. I didn't know if the particular/larger size of pea gravel made it ideal for some reason or if path fines would impede drainage as it's too fine/powdery, hence the post.
Old 12-08-2018, 10:46 AM   #6
retired framer
You could always just do a few feet of test run
Old 12-08-2018, 03:37 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,..... Is this dry creek, ever flow water,..??
If so, fines are much more likely to wash downhill, than larger aggregates,....
Msradell likes this.
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 11:57 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Sanity check - water collection for irrigation - from creek bed So cal Man Landscaping & Lawn Care 2 08-14-2008 06:16 PM
