Oak Tree Root Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-23-2018, 11:00 AM   #1
Rewards Points: 156
Oak tree root issue
Due to oak tree roots raising a section of the concrete sidewalk at the front door, I decided to remove two of the uplifted concrete sections and plan to rebuild the walk with gravel. Some of the roots further away from the entrance will need to be trimmed (or actually shaved off rather than cut out completely) in order to ensure the tops of the roots will remain under the surface of the new walkway. This will not be a major issue.
However, a large root runs directly in front of the concrete pad at the entryway to the front porch. See the attached photo. Due to the tight space between this root and the front door, and the overhanging porch, there is no effective way to create a bridge.
Obviously, completely cutting out this section of root will likely have a negative impact on the future health of the tree, which is probably over 50 years old. My question is this: If I actually "shave off" (using a sawzall or similar tool) the length of the root that extends above the concrete pad, will this be less detrimental to the health of the tree, since at least half the root will remain in place underneath the new walkway?
At some point I will have the tree taken down altogether, but that's a huge expense for another day in the future. I am trying to find a compromise solution to fix the problem as it is right now.
Thanks for anyone's professional or experienced input!
ggano is offline   Reply With Quote
Old 05-23-2018, 11:33 AM   #2
retired framer
Rewards Points: 20,804
Re: Oak tree root issue
An arborist would measure the diameter of the tree and use that to come up with a distance that it is safe to cut the root out.
Dead outlets + furnace issue kingtosh82 Electrical 9 05-16-2016 08:22 PM
Cutting into the root of a live oaks tree miamicuse Carpentry 10 04-12-2015 09:37 AM
Need arborist's advice on tree well diameter Leprechaun Landscaping & Lawn Care 7 04-11-2015 07:34 PM
My tree isn't looking so good. Pics inside Eds_tls Landscaping & Lawn Care 3 06-19-2013 03:35 AM
