Newly Seeded Yard - Sprinkler Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Canarywood1
Old 07-05-2017, 12:43 PM   #1
Rewards Points: 310
newly seeded yard - sprinkler question
just had our gardener seed a fairly large portion of our backyard. He added many new irrigation points (sprinkler nozzles) - seems the water spray is not hitting the entire yard based on using +15' nozzles. they are pop-ups, some 180 degree, and 360's down the middle. does anyone make a nozzle that sprays more than 15'?
KPDMinc is offline   Reply With Quote
Old 07-05-2017, 07:44 PM   #2
Rewards Points: 7,590
Re: newly seeded yard - sprinkler question
If he added more sprinkler heads to an existing system, without adding more zones (solenoid valves), could be that you don't have enough flow to spray very far.
Figure out what brand and model of sprinkler heads you have and google the instruction manuals. The rotaries possibly have different and/or adjustable nozzles. Not sure about the pop-ups.
My pop-ups only spray about 8 feet (but positioned so that is all they need to spray). My Hunter rotaries spray may 20-35 feet, but only 3 per zone and I have good water pressure and seems proper sized pipe to the heads.
SPS-1 is offline   Reply With Quote
Old 07-05-2017, 09:06 PM   #3
RRH
Rewards Points: 1,336
Yes pressure will have a lot to do with it. But may just need to switch to a something like a Rainbird Rotor Sprinkler.
RRH is offline   Reply With Quote
Old 07-11-2017, 01:57 PM   #4
Rewards Points: 122
Like others above have stated, yes they make heads that spray further however the residual water pressure has a lot to do with the number of spay heads you can run at the same time. The more water you flow will result in a drop of water pressure.
You can also try running your sprinklers at a time of day (or night) when the water pressure is greater.
Joeycarnuba is offline   Reply With Quote
Old 07-11-2017, 02:49 PM   #5
Rewards Points: 1,042
Just have the guy that installed the sprinkler system come back and make the needed adjustments.
stick\shift likes this.
Canarywood1 is offline   Reply With Quote
Yard Sprinkler Talk Mr.Boots Gardening Forum 2 05-15-2017 02:48 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Newly Installed Roof Drip Edge question w/pics searayrunner Roofing/Siding 30 06-17-2010 12:14 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
This is another sprinkler question deck hand Landscaping & Lawn Care 2 05-22-2008 07:16 AM
