Newly Planted Cedar Needles Turning Yellow - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By 47_47
  • 1 Post By homeimproverjoe
Old 06-18-2017, 01:16 PM   #1
Rewards Points: 616
Newly planted cedar needles turning yellow
I'm in Birmingham Alabama. Heavy clay soil. Just planted 3 Deodar Cedars from 15 pound containers into the ground about a month ago.
All three are showing some yellow needles. One in particular is showing lots more than the others. This tree also has some discoloring at the root ball that appears like a fungus of some sort.
Help!
homeimproverjoe is offline   Reply With Quote
Old 06-18-2017, 01:30 PM   #2
JUSTA MEMBER
Rewards Points: 4,022
Re: Newly planted cedar needles turning yellow
Are you sure that your soil has the proper nutrients that these need to thrive?
Some trees only grow in a base environment, others in an alkaline one.
Did you do a PH test to see what you have, then pick out a compatible tree, or think "It's pretty, it'll grow here"
ED
de-nagorg is online now   Reply With Quote
Old 06-18-2017, 03:50 PM   #3
Rewards Points: 4,238
This is an article about root rot. It does mention Deodar Cedars. You might have to amend the soil around the roots & water less. Could there still be some herbicide in the soil?
http://www.virginiagreenlawncare.com...-root-rot.html
You have very interesting soil. Probably similar to the Red Mountain just a few miles from you:
http://trekbirmingham.com/articles/the-story-of-red-mountain
Nik333 is online now   Reply With Quote
The Following User Says Thank You to Nik333 For This Useful Post:
homeimproverjoe (06-18-2017)
Old 06-18-2017, 04:04 PM   #4
Chert is very hard.
Old 06-18-2017, 06:54 PM   #5
Rewards Points: 1,042
Chert is a sedimentary stone, which will eventually over time turn into limestone, at this point it's more like silica.
Canarywood1 is offline   Reply With Quote
Old 06-19-2017, 06:47 AM   #6
Rewards Points: 616
Interesting, the dirt where this tree is planted is fill dirt used to create a berm to level the yard. They call this dirt "Chert". I added soil amendments to the hole before planting the tree. I'm going to be talking to the nursery this morning to see if they will send someone out to see what's going on.
My first thought was that the tree wasn't getting enough water. I suppose I may have to just dig up the root ball to check the roots in order to know for certain if its too dry or too wet or if the roots are rotted.
Old 06-19-2017, 08:44 AM   #7
47_47's Avatar
Rewards Points: 320
Can these trees handle your summer heat? Won't be causing them to brown, but they do look too close to the house and together.
Nik333 likes this.
47_47 is offline   Reply With Quote
Old 06-19-2017, 08:49 AM   #8
Rewards Points: 616
Update: I spoke to the nursery. They said since its only been planted a few weeks, it would not hurt to dig it up and inspect the roots. Said the yellowing may just be normal summer needle drop.
After digging around the top quarter of the tree, the roots look really good. I suppose I will go ahead and excavate the entire tree to be sure, but I'm a bit concerned with stressing the tree after seeing these top roots growing so well.
Thoughts?
Old 06-19-2017, 08:53 AM   #9
Rewards Points: 202
Simply an opinion, but you have good pictures and know what the soil is so I would go to the nursery rather than asking them to send someone out. Seems more apt to get a response sooner. Hasn't been often, but have had a few things like this come up over the years, have taken pictures with me, and that has been enough for them to be as certain as if they had actually been there. I do know though that we have had a number of new plantings and transplants over the years where they appeared to not be taking so well, sort of like you have, and gone into neutral or maybe even reverse for a bit, then a few months later adapt and take off, so they might tell you it's a matter of patience as much as anything.
The Following User Says Thank You to DexterII For This Useful Post:
homeimproverjoe (06-19-2017)
Old 06-19-2017, 08:56 AM   #10
Rewards Points: 616
Yes, the trees grow well here. They are planted at shopping malls and grocery store parking lots quite often.
This tree (one of 3 planted about a month ago) is yellowing from the inside. I'm trying to check the roots for signs of root rot. Otherwise, I'm just guessing that the tree has gotten too much water from the storms we've had recently and will recover in a few days.
Nik333 likes this.
The Following User Says Thank You to homeimproverjoe For This Useful Post:
47_47 (06-19-2017)
Old 06-19-2017, 09:55 AM   #11
Rewards Points: 616
Thanks Dexter, I did send the pics to the nursery earlier today. So, when we spoke, they were reviewing the pics to make their suggestions.
As long as it's not going to cause undue stress on the tree, I'm going to dig on one side down to the bottom of the root ball to inspect for root rot. Then I'm going to trench a channel from the bottom of the root ball down the hill a bit and fill it with amended soil and gravel to provide a drainage path for the root ball to help prevent "wet feet" issues.
Nik333 likes this.
Old 06-19-2017, 11:06 AM   #12
No one can say you're not a hard worker!
Old 06-19-2017, 02:57 PM   #13
Rewards Points: 616
Hard work is easy to come by, when you control the supply.
Smart work, that's another thing. Elusive
de-nagorg likes this.
Why is my paint turning yellow? Rickyrre Painting 9 08-05-2013 09:54 PM
white paint turning yellow victor Painting 40 11-13-2012 09:09 PM
Condensation tube water turning house yellow. Ipty94 HVAC 4 06-25-2011 01:45 PM
Fresh painted white baseboards turning yellow laurenkemp7 Painting 2 09-01-2009 08:26 AM
maple tree stump grindings turning grass yellow johnnyboy Landscaping & Lawn Care 4 08-21-2009 03:22 AM
