New First Homeowner. No Grass In Yard,we Gotta Fix That,but How? - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 03-10-2017, 07:28 AM   #16
Rewards Points: 36
Re: New First homeowner. No grass in yard,we gotta fix that,but how?
Chris015,
I'm in about the same situation. Just cut a bunch of trees and I'm hoping this will allow for some grass growth. I just want to do it the best way possible. I still have low and high spots. Good luck with your yard. This was a good post for me to read.
UnrulyNFS is offline   Reply With Quote
Old 03-10-2017, 07:31 AM   #17
Rewards Points: 36
Originally Posted by Cedrus View Post
You did not mention irrigation set up.....Your 3000 sq.ft. has been nicely compacted.
Why not a low growing ground cover like.....Thymus serpyllum or Mother of Thyme/Creeping Thyme ? Maybe 3" high and you can mow it back if needed. Moderate water.
What would this look like? I'm up for anything that covers the ground and prevents runoff.
Old 03-10-2017, 08:46 AM   #18
Rewards Points: 576
Do a Google search and visit local nurseries to see in person.
Cedrus is offline   Reply With Quote
Old 03-10-2017, 05:16 PM   #19
Rewards Points: 18
If you are going to use a ground cover rather than grass, i would highly recommend periwinkle also known as myrtle. It grows in sun or shade has a shiny green leaf and placed 6 inches apart in all directions will cover the area completely in 3 years. It requires zero maintenance. Personally i like the dark green leaf variety, but it also comes in a verigated (green leaf with yellow edge) that has a larger flower but it becomes hard to control.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 03-10-2017, 05:28 PM   #20
Rewards Points: 36
Would this have a good enough root system to prevent erosion. I've got a wooded area in the front yard that might benefit from this. I planted liriope, but it has been very slow to spread. It doesn't die easy, but it's not taking over in the dense clay soil like it does in the flower beds.
Old 03-10-2017, 05:29 PM   #21
Rewards Points: 36
So I just googled creeping thyme and have to say that I really like that.
Old 03-10-2017, 09:03 PM   #22
Rewards Points: 36
Does creeping thyme spread like grass seed, or does one have to start with individual plants. I think I'm gonna do a test run with some.
Old 03-11-2017, 06:47 AM   #23
Rewards Points: 18
Yes it definitely does. I use it as a "living mulch" under my trees which line the perimeter of my property. Much of it is on sloped ground.
I also use lirope in other areas. If you want it to spread and cover an area rapidly, dig each clump up in the spring, seperate it into 8 or 10 pieces, and replant each of those. Its more work for the first two years or so, but eventually it fills in and becomes maintenance free other than mowing it or weedwacking it down every spring.
Old 03-11-2017, 08:51 AM   #24
Rewards Points: 576
Periwinkle does not look good in full sun. It likes morning sun and afternoon shade. It grows a foot high and can be a habitat for unwanted critters.
Thyme puts out runners that root as they spread. If cost effective, buy flats of solid thyme and cut into 25 or more pieces and set out a foot apart. (Rough guess).
If you soil is still compacted it might need a light tilling. What is the status for irrigation water ?
Old 03-11-2017, 09:40 AM   #25
Rewards Points: 36
On my yard, just rain unless I water it. The wooded area is on the higher berm that separates the road and my property so it doesn't see runoff water/irrigation. I'm gonna take a bunch of pictures after it warms up so people have a better idea what the situation is. I used to mulch the leaves with the mower, but without vegetation, the soil erosion was bad. Until I can get the yard grass growing, I've left the leaves alone to prevent further soil loss.
Old 03-11-2017, 12:18 PM   #26
Rewards Points: 576
chris015.......did you find any of this interesting ?
help bermuda grow into patchy spots denemante Landscaping & Lawn Care 5 05-28-2014 10:06 AM
Synthetic grass, anyone have experience w/ it? NewHomeDIYGuy Landscaping & Lawn Care 8 03-05-2013 03:35 PM
Planting grass under old tree rightit Landscaping & Lawn Care 12 05-06-2011 08:53 AM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
