New Concrete Patio - Edge Draining? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-01-2018, 09:52 AM   #1
Rewards Points: 101
My new patio was finally poured last week and looks great. It is properly sloped away from the house for drainage, but I'm wondering if this is going to cause a swamp issue down the road as about 400 square feet that was previously dirt/grass is now going to be draining to an edge about 35' long.
I have not quite figured out what I am doing in terms of landscaping - right now the yard is all dirt. That will probably wait until spring at this point, but I'm wondering if I should (or even can) put in some drainage along the edge to disperse the water across more of the yard.
I am in SE Michigan. My soil is very sandy and drains quite quickly. Would a border of rocks/gravel be a good idea to allow water to drain down faster? Perforated pipe to a dry well?
Any advice to eliminate a problem before it happens is appreciated.
tev9999 is offline   Reply With Quote
Old 10-01-2018, 04:41 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: New Concrete Patio - Edge Draining?
Ayuh,..... So long as the grade along the 35' pitches Away from the house,.....
I wouldn't worry 'bout it,.....
Maybe scatter some contractor quik-green grass seed 'round the area,.....
It'll be grass before winter freeze up,.....
pavers over concrete patio need help! pchimeRDH Concrete, Stone & Masonry 2 04-22-2017 07:06 PM
Building Deck Using Existing Concrete Patio rosecurt6 Carpentry 11 04-20-2017 04:21 PM
Concrete Patio Nightmare 8trek Building & Construction 7 03-10-2014 10:02 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
