Nest In The Ground - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2014, 02:00 PM   #16
Rewards Points: 6,652
Originally Posted by Canarywood1 View Post
If that doesn't work, get a gallon of diesel fuel, and pour it in the nest at night but DO NOT IGNITE IT, they breathe through their bodies and the diesel will kill them.
Kerosene is cheaper and does the same thing. Same with Isopropyl Alcohol.
Old 09-17-2014, 05:10 PM   #17
Rewards Points: 356
Just wanted to give an update.. I went out one late evening last week and poured a cup full in and around the hole... It lightly rained overnight and I went out next day to check and it was still there covering the hole ... No activity at all... I cut the grass the next day and didn't have one problem... Im guessing it worked unless they were trapped in there... Well two days ago I noticed my yard was all tore up in the area and went out and something had dug a hole there about a foot deep... Must of been going for honey possibly.. But you could see pieces of a hive all shredded... Now I have a foot deep hole but the bees are gone
timothy300858 is offline   Reply With Quote
The Following User Says Thank You to timothy300858 For This Useful Post:
oh'mike (09-17-2014)
Old 09-17-2014, 05:20 PM   #18
Bear most likely. Or a neighbor that was waiting for you to kill off the suckers.
Old 09-17-2014, 06:07 PM   #19
r0ckstarr's Avatar
Rewards Points: 82
Yellow jackets don't make honey.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
nanuk (09-17-2014)
Old 09-17-2014, 06:25 PM   #20
Rewards Points: 1,042
Cup full of WHAT????
Canarywood1 is offline   Reply With Quote
Old 09-17-2014, 07:05 PM   #21
Retired Moderator
Rewards Points: 7,174
Sevin dust.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 04:37 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
