Nest In The Ground - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-10-2014, 05:20 PM   #1
Rewards Points: 356
Nest in the ground
So Ive been stung a total of 6 times the last 2 times Ive cut the grass. Ive recently noticed there is def a nest in the ground seeing I was stung in the same area of the yard both times. So I just came back in from going through 2 big cans of killer and it doesn't seem to do anything ... Im assuming they are yellow jackets but possibly bees.. Im in Nw Indiana and ive been told lots of folks have been getting stung cutting the grass... When I get stung, it hurts like hell but no stinger is left.. The spot is red and swells slightly and itches quite a bit... It eventually goes away in a day or two.. It basically feels like they divebomb in and sting and take off.. Now I obviously know I run over the hole in the ground with the mower... Any ideas on how to get rid of it completely??? Might sound funny but my yard is a mess and Im half tempted to load it up with gas and light the area on fire... Any help would be much appreciated... Thanks in advance
timothy300858 is offline   Reply With Quote
Old 09-10-2014, 05:28 PM   #2
Rewards Points: 6,652
You can get Dry Ice and shove it down the hole, while it is dark out. You can also call an exterminator to take care of it. They have better killing agents than you can get at the store.
Old 09-10-2014, 06:22 PM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 68
Dry ice works and gasoline does work but you don't have to ignite it. Pour some in the hole at night and then cover the hole with a rag, etc. The fumes alone will kill most if not all of the bees.
Old 09-10-2014, 10:04 PM   #4
Rewards Points: 1,808
I get yellow jacket nests now and then in my lawn. Happens during a long dry spell. I take a gallon pail filled with play sand that comes in 20lb bags from Home Depot, walk up and quickly pour it right on the hole. It will run like water into the nest and they won't be able to dig out.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
Gymschu (09-10-2014)
Old 09-10-2014, 11:37 PM   #5
I had several yellow jacket nests this summer and searched the Internet at length for a way to kill them. I didn't want to pour gas cause I wanted the grass to live. I saw someone who suggested pouring Sevin dust in the hole at dusk and then sprinkle some more around the perimeter. I tried it and next morning there was zero activity in the nest. I was shocked at how well it worked!
sbm2012 is offline   Reply With Quote
The Following 2 Users Say Thank You to sbm2012 For This Useful Post:
gregzoll (09-11-2014), oh'mike (09-11-2014)
Old 09-10-2014, 11:42 PM   #6
Rewards Points: 356
Ive never heard of it... Any ideas on where to find it???
Old 09-11-2014, 06:48 AM   #7
Retired Moderator
Rewards Points: 7,174
Go buy a bag or can of Sevin dust---locate the nest---and pour a large cup of the powder on top of the opening.---best to do this at night or early morning---
the nest will be dead in a matter of hours.
Old 09-11-2014, 08:14 AM   #8
Rewards Points: 206
Your local mill, nursery, hardware, or in the gardening section of a big box.
As mentioned, in and around the hole, and they'll take it right into the nest for you.
Old 09-11-2014, 09:58 AM   #9
Rewards Points: 356
I will def go looking for it this morning... Hopefully it works because Id love to cut the grass atleast 2 more times... But its been a complete downpoor here the last couple days so the grass will wait... thanks a lot guys
Old 09-11-2014, 02:06 PM   #10
Rewards Points: 35
I've gotten rid of a ground nest by pouring a gallon jug of lemon scented ammonia down the hole and then covering it with a heavy bowl for the night. It didn't leave any dead grass at all.
d189379 is offline   Reply With Quote
Old 09-11-2014, 02:27 PM   #11
Sven actually contains Diatomaceous earth in it. They get that on them, and it cuts into their bodies.
The Following User Says Thank You to gregzoll For This Useful Post:
timothy300858 (09-11-2014)
Old 09-11-2014, 03:31 PM   #12
Rewards Points: 356
I picked me up a bag of it... Will give it a shot tonight... thanks everyone
The Following 3 Users Say Thank You to timothy300858 For This Useful Post:
gregzoll (09-11-2014), oh'mike (09-11-2014), r0ckstarr (09-11-2014)
Old 09-11-2014, 06:54 PM   #13
r0ckstarr's Avatar
Rewards Points: 82
Nuke it from orbit. It's the only way to be sure.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
Old 09-12-2014, 11:30 AM   #14
Rewards Points: 2,440
Post back with your results please!
bob22 is online now   Reply With Quote
Old 09-12-2014, 02:31 PM   #15
Rewards Points: 1,042
If that doesn't work, get a gallon of diesel fuel, and pour it in the nest at night but DO NOT IGNITE IT, they breathe through their bodies and the diesel will kill them.
Canarywood1 is offline   Reply With Quote
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 10:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 05:37 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
