Need Sump Pump For French Drain - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-01-2014, 12:14 PM   #1
Rewards Points: 45
Need sump pump for french drain
I have a soggy lawn problem that I'm trying to solve. I dug a ditch for a french drain and used a post hole digger to dig a pit for the water to drain into. The ditch is helping but the pit doesn't drain quickly. I was thinking of putting a small submersible pump into the pit to move the water off of my lawn area. The pump doesn't have to move a lot of water but it needs to be fairly small, and I'd prefer to use a low voltage pump if possible. I would have to run a fairly long power cable (about 100 ft.) from my house to the pump. I would like to know if anyone might have suggestions for specific pumps to use.
rvmeush is offline   Reply With Quote
Old 12-24-2014, 02:51 PM   #2
Rewards Points: 22
Try the Harbor Freight website. They carry several submersible pumps at reasonable prices, most with a off/on switch that floats. However they are all 110. I had a setup similar to yours at my old house and had good luck with their smaller pump. However, did not have a 100 ft power run.
Ronnie1a is offline   Reply With Quote
Old 12-25-2014, 02:51 PM   #3
Oso954's Avatar
Rewards Points: 1,966
You are going to need a fairly large wire to run low voltage 100 ft. The voltage drop on a 12V system is much worse than on 120V.
120V is most likely the less expensive way to do it.
Oso954 is online now   Reply With Quote
Old 12-25-2014, 05:08 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Where ya gonna pump it Too,..??
Old 12-25-2014, 05:59 PM   #5
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,194
I dug a ditch for a french drain and used a post hole digger to dig a pit for the water to drain into. The ditch is helping but the pit doesn't drain quickly. I was thinking of putting a small submersible pump in...
I would like to know if anyone might have suggestions...
Keep digging more ditch.
12-18" below grade should be plenty then lay in some perforated drain pipe.
The one I did ends at a storm water culvert.
Sump pump w/o perimeter drain? strategery Building & Construction 5 06-20-2014 08:07 PM
Sump Pump Drain Corngrower Plumbing 3 04-12-2012 10:52 AM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 12:21 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
