Need To Some Really Strong Weed Killer - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 07-12-2017, 06:51 AM   #16
ZTMAN's Avatar
Rewards Points: 342
Re: Need to some really strong weed killer
Pump sprayer with concentrate. I spray a lot at our hunting camp so I buy the concentrate in a 2.5 gal jug:
http://www.homedepot.com/p/HDX-2-5-G...7760/206643925
HDX kills just like the name brand. Only difference I see is that you will see results from the name brand in a day or two. HDX takes about a week. The 2.5 gal. jug makes a heck of a lot of weed killer and you cant beat the price
SeniorSitizen likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 07-12-2017, 11:41 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,678
If you want it really gone and nothing will grow back for a long time get some rock salt. We had poison ivy I just couldn't kill, poured the salt and water off an ice cream freezer, that took care of that, never did come back, but after several months the grass came back. I have put rock salt on other things I wanted dead, always worked for me.
Nik333 likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
AvalonGirl (08-04-2017)
Old 07-12-2017, 12:44 PM   #18
Knows Enough to be Danger
Rewards Points: 1,219
You won't spray a 16x20 area by hand???
Assuming that came out wrong, I'd do some Roundup in a pump pot. Buy the concentrate and mix it a little hotter if you'd like. And if it is mostly broadleaf weeds (not grass) I'd maybe consider a 2,4-D approach. A little more effective on your non-grasses.
NickTheGreat is offline   Reply With Quote
Old 07-12-2017, 12:49 PM   #19
Rewards Points: 270
when i said i wouldnt spray that size by hand, i meant using the premixed kind that comes in its own sprayer, never seems to spray correctly or alot of work just to spray, thats why i said for ones and twos in the driveway its ok..
Ill have to see if i can find my sprayer and check out the concentrate to do that..
And the rock salt sounds like another option...
cubangt is offline   Reply With Quote
Old 07-17-2017, 10:13 AM   #20
Rewards Points: 270
Found my pump sprayer, has anyone ever used this brand? may try this one for the long term control
http://www.homedepot.com/p/RM43-32-o...6502/205748220
Old 07-17-2017, 10:15 AM   #21
Rewards Points: 270
Or this one..
http://www.homedepot.com/p/Compare-N...-203112356-_-N
Old 07-17-2017, 10:21 AM   #22
ZTMAN's Avatar
Rewards Points: 342
Why don't you want to consider the 2.5 gal concentrate that was identified in post 16
Old 07-17-2017, 10:22 AM   #23
Rewards Points: 1,594
As near as my ole eyes can tell when I zoom them, they are both 41percent glyphosate so I would probably buy the lesser expensive and use the difference in price to take the wife out for a cheeep lunch.
Old 07-17-2017, 10:39 AM   #24
Unless they do a hell-of-ah lot of spraying, @ 1.5 oz. of concentrate / Ot. of water that 2.5 gallon jug will be on the storage shelf for 10 to 20 years.
Old 07-17-2017, 11:30 AM   #25
Rewards Points: 2,378
Originally Posted by KPDMinc View Post
Ive always had good luck with Roundup. Can always try diesel fuel too...
Why pollute the ground water?
Nik333 likes this.
bob22 is offline   Reply With Quote
Old 07-17-2017, 11:43 AM   #26
Rewards Points: 270
i went with the same brand, just smaller bottle, the 32oz instead of the 2.5 gal..
Old 07-17-2017, 02:21 PM   #27
ZTMAN's Avatar
Rewards Points: 342
You are probably right Senior for the average homeowner. I just see that cost per oz. price and go for the big jug vs the small one. Warehouse shopping mentality.
Works for me because I spray a lot, but even so a jug will last me two years.
Old 07-17-2017, 06:33 PM   #28
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Originally Posted by cubangt View Post
I have a concrete patio that has been over grown with weeds and in some cases grass, i need something that is strong to kill the weeds and grass that is growing thru and over my patio..
Your typical big box store sprays are a waste, i need something that will last and kill down to the roots..
suggestions?
Ayuh,.... Clorox,.... Right outa the jug, it'll kill any weed, Dead,....
Old 07-20-2017, 07:12 AM   #29
Rewards Points: 297
If you want faster results, you can Try RoundUp Quick Pro. It's available in easy-to-mix packets that require no measuring (1 packet per gallon). It has an extra herbicide for faster "knock down", usually in about 2 days.
https://www.amazon.com/Roundup-Quick...undup+quickpro
I would also recommend using a surfactant for better results:
https://www.amazon.com/Southern-Ag-S...reader+sticker
Finally, do yourself a favor and buy a *nice* sprayer. The $10 ones from the home store are great as "throw away" units, but fail quickly and can be frustrating to use. The quality difference in a $10 sprayer and a $40 sprayer is night and day.
https://www.amazon.com/Chapin-26021X...chapin+sprayer
red92s is offline   Reply With Quote
Old 07-27-2017, 11:26 AM   #30
Rewards Points: 270
Finally applied the weed killer yesterday after work... we will see how it works out..
will post back results.. less than 24hrs, no visible changes, but im not in a hurry, as long as it works..
I did notice that in my 1st sprayer that i cleaned out and used for the insect killer, whatever i had in there and emptied into the area i wanted to kill the weeds it killed everything within 24hr period. all brown and dried up, not sure what i had in there, but that seemed to work as well..
Organic Weed Killer Lanco Landscaping & Lawn Care 7 05-09-2017 05:50 PM
Lawn was fertilized 6-13-10 and want to apply weed killer TDHUEY Landscaping & Lawn Care 1 06-28-2010 06:39 PM
Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 whataboutj Landscaping & Lawn Care 25 05-13-2010 10:01 PM
Overseeded in fall: How long to wait until weed killer? C_J_GO Landscaping & Lawn Care 10 02-23-2010 10:38 AM
Weed Killer cgoll Landscaping & Lawn Care 3 05-09-2009 10:17 AM
