Need To Identify Sprinkler Wires - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-29-2020, 06:11 PM   #1
Rewards Points: 118
need to identify sprinkler wires
guys i have a multi-meter and need to identify sprinkler wires in the field and match them to wires at the clock.
since i cannot connect both ends i cant check continuity right ?
any ideas ?
xclaim is offline   Reply With Quote
Old 03-29-2020, 07:32 PM   #2
Rewards Points: 10,814
Re: need to identify sprinkler wires
Connect them at random to your controller. Then run each zone and you will have identified which wire is connected to which zone. Then, if you want, you can move the connections on the controller. For example you might want zone 1 to be the soutwest corner of the front yard, and then the zones going clockwise when viewed from above.
SPS-1 is online now   Reply With Quote
Tags
break in wire , sprinkler irrigation
