Need Help: Sprinkler System Leaking - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Yodaman
  • 1 Post By LawnGuyLandSparky
Old 02-20-2017, 11:35 AM   #1
Rewards Points: 4
Need Help: Sprinkler system leaking
My sprinkler system is leaking. I replaced the diaphragms on the valves, but this has not stopped it. Any help would be appreciated.
grfbiz is offline   Reply With Quote
Old 02-20-2017, 12:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Re: Need Help: Sprinkler system leaking
Ayuh,... Where, Exactly, is it leakin',..??
Bondo is online now   Reply With Quote
Old 02-20-2017, 07:18 PM   #3
Rewards Points: 4
It is leaking from the sprinkler heads.
Old 02-20-2017, 07:25 PM   #4
Property Mgt/Maint
Rewards Points: 6,518
If leaking from more than one head, I would immediately look at the line PSI and determine if it's too high
Msradell likes this.
Yodaman is online now   Reply With Quote
Old 02-21-2017, 07:48 PM   #5
Rewards Points: 22
i had that same issue and just replacing the diaphragms seal on the valves didn't work, i had to replace the whole thing ( valve) the valve is cheap $15 and comes with a new solenoid, but the label is the time consuming part.
pixelss is offline   Reply With Quote
Old 02-22-2017, 12:23 AM   #6
Rewards Points: 266
Make sure they are screwed in tight.
They break and come loose after they are hit from lawnmowers and being walked on.
DallasCowboys is offline   Reply With Quote
Old 02-22-2017, 09:49 AM   #7
Rewards Points: 3,420
That wouldn't make them leak when the system is off. The control valves are allowing water to pass when it is not desired.
LawnGuyLandSparky is offline   Reply With Quote
My sprinkler system will never run again mj12 Landscaping & Lawn Care 1 06-20-2016 06:12 PM
Sprinkler system Italgrl Landscaping & Lawn Care 3 05-22-2014 10:39 PM
Sprinkler System or No Sprinkler System hoppyhere Landscaping & Lawn Care 5 07-29-2013 05:25 PM
Sprinkler System Causing Other GFCIs to trip patented Electrical 7 05-29-2013 10:42 AM
Purged air from hydronic baseboard heat system, now pressure relief is leaking! HELP! rodney23 HVAC 1 10-03-2010 08:40 AM
