Need Help Identifying Sprinkler Controller Wires - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-22-2017, 11:06 PM   #1
Rewards Points: 8
Need help identifying sprinkler controller wires
Hello all, I've lurked a while and gotten some good information, but this is my first post. Long story coming -- but short story is I'm trying to figure out what the wires in my controller are from/for.
We bought our home a little over a year ago. Chicago western suburb area. Previous owners were elderly and I don't think kept up with too much maintenance, including the in ground irrigation system. End of last year the Irritrol controller in the garage stopped working. We had a local landscaping company come and install a new box -- they put in a Hunter Pro-C.
Our property has 7 zones.
This year I've begun thinking of swapping the controller out for a smart controller, mostly so the system behaves more intelligently regarding rain events. Before I attempt this though, I wanted to make sure I know what all the wires in my current setup are for.
Inside of my current Hunter Pro-C controller, in the bottom right, there are actually two separate bundles of wires that come up into the controller.
The larger bundle carries all the multicolored wires that plug into stations 1-7, as well as 1 white wire, which is plugged into "COM" at the very bottom -- common wire I'm assuming. This bundle also carries a black and a grey cable that are plugged into two separate terminals each marked "SEN", which is for a rain/weather sensor. There are also 3 unused wires that remain unstripped.
The smaller bundle has just two wires -- 1 white one, which is also plugged into "COM" at the bottom, and 1 red one, which is not attached to anything.
I'm trying to figure out what that red wire is for -- especially since the end is stripped, which makes me think it was used for something in the past, and is supposed to be plugged in somewhere.
This got me to looking around the outside of the house, where I found a cut wire bundle, with just a white and red cable inside. Next to it was a Rain Bird Rain Check shutoff sensor.
My simple brain says, small bundle with 1 white and 1 red wire -- and in the controller box there is a similar small bundle with 1 white and 1 red wire -- is it possible my controller is wrongly wired? And that inside it the 1 white COM wire and the 1 unattached red wire are actually supposed to go to SEN since the other end of the wire, that used to be attached to the rain sensor before it got cut, are the same white/red colors? I don't really care that there is no rain sensor at this time -- I'm just running the controller on BYPASS.
Then what are the black/grey wires that are currently in the SEN terminals for? I plugged both the black and the grey wires into one of the PCM modules and manually ran those stations, but no sprinklers popped up. Again, the black and grey wires come up in the same bundle as the rest of the multicolor wires that go to stations 1-7.
I called Rain Bird and asked them, is it possible that on the sensor end, the wire is white/red, but somehow by the time it gets to the controller, the wires are different colors. They said that sometimes with the old Rain Check sensor, the wires would go to the ? solenoids first, and then get spliced to the controller, and therefore might have different colors. This part was over my head.
The other question I have is, do I have a master valve, or how can I find out? In the bottom PCM module, the terminal for P/MV is empty. My water supply and RPZ are in the basement. Is the master valve usually something I can see?
I understand a blue box down there labeled "Munro Pump" is a booster pump. But the gray power cable that comes out from underneath it is UNPLUGGED ... Is this supposed to be plugged in? Or put another way, does it make sense that my sprinklers still work even though this Munro Pump is unplugged? There is a sticker on the bottom right that says "Multiple power sources" -- maybe there's another power source somewhere.
LOOOONG post. I appreciate any and all input anyone can provide.
Thanks!
Beardown34 is offline   Reply With Quote
Old 08-23-2017, 07:50 AM   #2
Rewards Points: 188
Re: Need help identifying sprinkler controller wires
The wires connected to 1 -7 and COM would transfer to your new controller the same way.
Take a look in your valve box(es) to see if black and grey are in the bundle and if they are connected to anything.
Additionally for the black and gray wires as well as the red/white combo you can do a continuity test if you have a multimeter. Disconnect the wires from the controller and connect them together black to gray and separately red to white. Go to the other ends and put your multimeter leads on the wires. If you have continuity then you have the right wires and you will be able to figure out what they do.
If you switch the controller off of bypass does it stop working?
Dan
djlandkpl is online now   Reply With Quote
Old 08-23-2017, 10:13 AM   #3
Rewards Points: 8
Thanks -- will check it out
Old 08-23-2017, 10:14 AM   #4
Rewards Points: 8
Yes if I take it off bypass, the controller says SEN OFF and the system doesn't run.
OK I left the wall controller on. I inserted the Red + White into the two SEN terminals. I went to the yard where the cut wire is, and touched the multimeter to the Red + White. No voltage, even if I flipped the black/red leads of my multimeter.
I then put the Grey + Black wires into the two SEN terminals (ie. the original configuration). Went out to the yard to the cut wire, and touched the multimeter to the Red + White. The voltage bounced around 24-28V.
Soooo I guess this indicates that the Red + White of the cut wire is continuous with the Grey + Black in my controller box?
And what might the unattached Red wire in my controller box be then? And what would the white common wire that comes with it be for?
** Also, how can I tell if I have a master valve in my system or not? Is it something visible in my basement, where the water supply and RPZ are?
** Also, what is this box for in my basement? Someone told me it's a booster pump? But it's disconnected ... yet my sprinkler system still works.
Thanks for all the help!!
Old 08-23-2017, 07:20 PM   #5
Rewards Points: 188
If you have a master valve, you'll find another valve somewhere that is in the water line before your other valves.
I don't know anything about the pump. Just a guess that the red/white pair were used to trigger the pump.
Dan
Old 08-23-2017, 09:32 PM   #6
Msradell's Avatar
Rewards Points: 818
If your system is working fine without the pump turned on there's no need for it. It's quite possible that when the system was installed the water pressure in your area with lower but since then work is been done on the system that raise your incoming pressure. In most areas city water pressure is sufficient to run sprinkler system without the need for booster pumps.
As far as the wiring goes it sounds like your well on the way to fix that problem, hope it all goes well.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 08-23-2017, 11:31 PM   #7
Rewards Points: 8
The cut wire in my yard has a red + white cable. I'm guessing the white cable is the common wire right?
But according to my continuity test, the wires in my controller box that create continuity are the grey and black cables attached to SEN. Is one of those two supposed to be a common wire?
I ask because there are already two white wires in my controller box, hooked up to the COM terminal. One white wire from the large bundle with the zone 1-7 wires. The other white wire is bundled with a Red wire, but as stated above, according to my continuity test, it doesn't seem to be continuous with the Red + White cut wire in my yard, despite looking the same.
Old 08-23-2017, 11:41 PM   #8
Rewards Points: 8
Is the master valve something I'll be able to physically see in my basement?
Or "in the water line before your other valves" meaning somewhere buried in-ground?
Old 08-24-2017, 07:24 AM   #9
Rewards Points: 188
Any way to trace where the wire runs in/along the house. My guess is that it may have been used for the rain sensor and then abandoned. Try disconnecting the white from the COM terminal and see if anything stops working.
Dan
Old 08-24-2017, 07:26 AM   #10
Rewards Points: 188
If you have a master valve it could be anywhere but it would be before your other valves. The master valve is designed to stop water flow to your entire system in case one of the zone valves fails.
Since your system is working, I doubt you have a master valve.
Dan
Old 08-24-2017, 08:47 AM   #11
Rewards Points: 8
These are great points djandkpl!
So most master valves are normally off?
Meaning if I have a master valve in my system, but someone forgot to wire it to power in the controller (or wired it incorrectly, or the wires got cut-- point being no power to the master valve), then the valve would stay closed and I would have no water coming out of the zones?
If this is the case, then I feel confident my system DOESN'T have a master valve, because my irrigation works even though nothing is plugged into the P/MV terminal on my controller.
That's also a good troubleshooting technique with the common wire. I have two wires going into my COM terminal. One of them is bundled with the multicolor wires from my watering zones. So if I disconnect that one, my watering zones should stop working?
And if I disconnect the other white wire ... I'm guessing nothing's going to stop working. The rain sensor wire is cut, and the system is on bypass. I don't know what else an extra common wire would be controlling. Unless it has something to do with that blue pump in my basement ... ("booster pump"?)
Old 08-24-2017, 06:13 PM   #12
Rewards Points: 188
Correct about the master valve. My guess is the white/red pair were used at some point but abandoned. If for some reason it's being used as a common for a zone, that zone will stop working.
See if you can find a red/white cable near the pump. That might solve the mystery.
Dan
Old 08-24-2017, 07:28 PM   #13
Rewards Points: 8
Ok then considering nothing in the controller box is wired in the P/MV terminal yet my irrigation works, I feel confident I do not have a master valve in my system.
Regarding the grey and black cables in the two SEN terminals, that are continuous with the cut red/white cable in my yard -- is it possible that red cable for connected or spliced somewhere to become two cables? Meaning the 1 red cable became both the black and grey? I ask because I'm wondering if one of the black and grey is the common wire for what was the rain sensor, or if the other unaccounted for white wire in my COM terminal is the common wire for what was my rain sensor.
Old 08-24-2017, 10:59 PM   #14
Rewards Points: 188
You would need to do a continuity test to test your theory. My system has 6 valve boxes and 3 junctions where wires join and colors change. Anything is possible...
Dan
Yard Sprinkler Talk Mr.Boots Gardening Forum 2 05-15-2017 02:48 PM
Sprinkler Wiring Mhale0369 Electrical 2 06-28-2015 07:59 PM
Identifying problem in heater system - super old wires? estockme HVAC 19 11-13-2014 03:26 PM
Sprinkler Troubleshooting??? mopowers Landscaping & Lawn Care 17 05-10-2010 04:44 PM
Identifying wires in a three way switch bergs4 Electrical 15 07-29-2009 10:33 PM
