Need Drip Or Bubblers Hooked Up - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-12-2016, 04:24 PM   #1
Rewards Points: 8
Need Drip or bubblers hooked up
I have two raised planter beds that I want to run water to. I have a 1" supply line on one side of the backyard in one of the raised planter beds. I also have a 3/4" line that runs under the deck 50ft to the other planter bed on the other side of the back yard. ( pool builder did this). They said I can keep the valves on the supply side and run the 3/4" line to send water to the other side. Right or wrong it's what I have.
So, I need to water sago palms, date palm, birds of paradise, and other small plants. I am thinking either a drip line or bubbler would work much better than a spray head?
So can I run both sides with one valve acting as 1 zone since drip and bubblers use much less pressure?
Can I use a regular brass Anti-siphon like a champion or Orbit or do I need a special drip/bubbler valve?
My plan with one valve was to add a "tee" on the outgoing side of the valve so I could supply both sides of the back yard.
one planter bed is 40' long the other is 21ft long (this one is 50ft away from the water supply.
thanks!!
titan77 is offline   Reply With Quote
Roof drip edge after re-siding job MI-Roger Roofing/Siding 9 02-05-2016 05:58 PM
Drip Edge for Low Slope Roof Martin5 General DIY Discussions 3 10-26-2015 12:52 PM
Periodic Shower Drip Wetchick Plumbing 3 10-10-2012 08:34 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
