Need Backyard Drainage Suggestions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 04-01-2018, 12:19 AM   #1
Rewards Points: 323
Need backyard drainage suggestions
My backyard fills up just a bit in some areas when it rains. Can i just dig a pit and fill it with pea gravel without pipes routing the water elsewhere? Would that work?
johnv713 is offline   Reply With Quote
Old 04-01-2018, 12:24 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Need backyard drainage suggestions
It might. Depends on the soil underneath. You need to do a perk test to see if it would drain sufficiently.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-01-2018, 01:23 AM   #3
Rewards Points: 323
Soil has some clayd in it, probably 30% .How deep do i have to dig and do i need to wrap the gravels in yard fabric. My plan is to dig a pit, fill it with the gravels and cover it up with the extracted soils.
Old 04-01-2018, 05:55 AM   #4
Rewards Points: 2,002
Just me, and if the property allows it...before I would do all that digging and rock purchase/labor. I would order some top soil and have it dumped somewhere in the yard. Wheelbarrow it to the holes and then grade it to pitch the water away. Seed it, grow it, mow it and not have to worry about the heavy rains that will overwhelm any ...gravel in a pit fix. JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 04-01-2018, 08:06 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Nope,..... Not just you,.....
Regradin' is a much better answer,....
A huge hole in the ground, fulla rocks is still gonna fill up with water,....
Old 04-01-2018, 08:09 AM   #6
retired painter
Rewards Points: 1,864
How often the yard fills with water will give you a good idea of how effective a pit would be. I agree with trying regrading first.
mark sr is offline   Reply With Quote
Old 04-01-2018, 10:16 AM   #7
Rewards Points: 323
Regrading is a great idea, but that would mean i have to do it on a grander scale because i have 12"x12" pavers cover 90% of my yard. Beside where would i grade it to? The drain hole to the street is in an odd location that requires water to make a 90 degree turn to get to.
Old 04-01-2018, 10:20 AM   #8
Guapo
Rewards Points: 11,950
May I suggest a drywell called Flo-well sold at Home Depot?
https://www.homedepot.com/p/NDS-24-i...AS24/100377387
Guap0_ is offline   Reply With Quote
Old 04-01-2018, 10:37 AM   #9
Amazing how pictures help............
Old 04-01-2018, 03:38 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 2,218
A drywell will collect the water but you still have to have reasonable soil porosity or attach weeping tiles to drain it away. If the water ponds and doesn't disappear in a reasonable time then your soil is either not very porous or already saturated. I vote for re-grading. We're making assumptions here because we can't see what you see.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 04-01-2018, 03:46 PM   #11
Guapo
I agree that the soil has to be able to handle the water. Keep in mind that there will be more time for that to happen since the drywell will be underground & should be surrounded with gravel. Don't get me wrong. I'm all for proper grading.
Old 04-01-2018, 11:03 PM   #12
Rewards Points: 1,222
That could be part of the problem right there.
The best advice is always given from some Crazy Guy on the Internet.
Right Wing= too closed minded to ever learn & grow
Left Wing= so opened minded all brains fell out
CrazyGuy is offline   Reply With Quote
Old 04-02-2018, 06:39 AM   #13
Bondo's Avatar
Ayuh,..... Where ever, Downhill is,......
mark sr and Gregsoldtruck79 like this.
Old 04-02-2018, 06:55 AM   #14
Good one Bondo,
But the OP may have a yard like my home does, a yard that has no "downhill" basically. The idiot builder in 1959 cut down a existing sloping lot almost level with the street, dug a crawl space on it and then built this house on it.
It sits on a foundation of cinder blocks that should have come up 2 more rows, with just one of those needed rows of block....JUST to get it up even with the grass.
Old 04-02-2018, 08:22 AM   #15
Guapo
If there is no downhill, follow what I said in post #8.
Backyard Drainage Issue bobssurfin Landscaping & Lawn Care 16 09-30-2009 02:18 PM
Backyard drainage rick32 Landscaping & Lawn Care 6 08-25-2009 10:34 PM
Backyard Drainage How Deep? dbeers16 Landscaping & Lawn Care 12 07-21-2009 08:41 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
