Need Advise On Sprinker Heads - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By djlandkpl
Old 06-15-2018, 06:28 PM   #1
Rewards Points: 640
need advise on sprinker heads
I have a about 25x25 area of grass with 12 sprinker heads separated into 3 zones.
My sprinker heads are completely missing the grass closer to the nozzle in some area due to the nozzles are only getting the area at least 4-5 feet away leaving a lot of brown spots.
I'm looking to replace either the head or the entire body with something that can provide better coverage throughout. Can you recommend a good one?
I found that rainbird has a U series which supposed to provide better close range area. Before I jump on it, just wanted to see what everyone is using.
dannieboiz is offline   Reply With Quote
Old 06-15-2018, 09:52 PM   #2
Rewards Points: 188
Re: need advise on sprinker heads
I like the rotary nozzles Rainbird R-VAN over the fixed spray. Do your head spray patterns overlap?
Msradell likes this.
Dan
djlandkpl is offline   Reply With Quote
Old 06-15-2018, 10:00 PM   #3
Rewards Points: 640
They do overlap but it just doesn't seem to have enough of it.
Old 06-16-2018, 08:47 AM   #4
Rewards Points: 576
Probably your water is coming out in a fine mist....is there a way that you can adjust to shorten the throw..and produce larger drops...which might help. Are there other nozzles that are interchangeable ?
It was not clear to me...are these the old brass pop ups or something else ?
Cedrus is offline   Reply With Quote
Adding a few sprinkler heads to existing argh Landscaping & Lawn Care 10 03-16-2018 11:31 AM
Capping off 75% of sprinkler heads? Re-planning sprinkler system? denemante Landscaping & Lawn Care 3 11-12-2014 12:11 AM
Adjustable Sprinkler Heads For Narrow Parkways? Trese Landscaping & Lawn Care 9 06-07-2014 06:23 PM
capping off rain bird heads? denemante Landscaping & Lawn Care 1 05-15-2013 11:45 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
