DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   need advise on sprinker heads (https://www.diychatroom.com/f16/need-advise-sprinker-heads-633255/)
dannieboiz 06-15-2018 06:28 PM
I have a about 25x25 area of grass with 12 sprinker heads separated into 3 zones.
My sprinker heads are completely missing the grass closer to the nozzle in some area due to the nozzles are only getting the area at least 4-5 feet away leaving a lot of brown spots.
I'm looking to replace either the head or the entire body with something that can provide better coverage throughout. Can you recommend a good one?
I found that rainbird has a U series which supposed to provide better close range area. Before I jump on it, just wanted to see what everyone is using.
djlandkpl 06-15-2018 09:52 PM
Re: need advise on sprinker heads
I like the rotary nozzles Rainbird R-VAN over the fixed spray. Do your head spray patterns overlap?
dannieboiz 06-15-2018 10:00 PM
They do overlap but it just doesn't seem to have enough of it.
Cedrus 06-16-2018 08:47 AM
Probably your water is coming out in a fine mist....is there a way that you can adjust to shorten the throw..and produce larger drops...which might help. Are there other nozzles that are interchangeable ?
It was not clear to me...are these the old brass pop ups or something else ?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
