Need Advice On Compacting A Raised Paver Patio Please!! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By abrowning
  • 1 Post By Bud9051
  • 1 Post By Melissa396
Old 07-25-2017, 01:58 PM   #1
Melissa396's Avatar
Need advice on compacting a raised paver patio please!!
We are building a 600 square-foot raised paver patio. It has a base of 6 inches that has been compacted every 2 inches. We have a 1 inch layer of sand. The pavers will extend on top of a 12 inch retaining wall (with concrete adhesive). We are wondering if we need to compact the finished patio and are worried that if we do it will sink lower than the retaining wall. Also, we are worried that the compactor would disturb the adhesive between the pavers and retaining wall. And lastly if we do need to compact should we put sand in the joints before or after compacting?
Melissa396 is offline   Reply With Quote
Old 07-25-2017, 03:50 PM   #2
Rewards Points: 6,122
Re: Need advice on compacting a raised paver patio please!!
Difficult choice with the pavers being glued to the top of that wall. IMO they will definitely sink when compacted and yes you would want sand inbetween. If you don't put the sand inbetween it will squeeze up from below, it will anyway but less.
What size pavers are you using and what pattern? Could you top the wall with secured pavers and then set your floating patio to the inside, a bit high to allow for sinking? Then, if it sinks too much, now or over time, you could pull the floating area and add more sand.
Bud
Bud9051 is offline   Reply With Quote
Old 07-25-2017, 04:52 PM   #3
Rewards Points: 44
I think it's pretty likely that the pavers will move relative to the wall. You want to run a compactor over the pavers when they're all down and that right there will cause them to sink a bit and really lock together.
I probably would have made a decorative retaining wall and paved right up to it about 1/4" to 3/8" higher. Assuming you did a decent job of compacting the gravel the pavers would settle about a 1/4" to 3/8" after compaction.
At least this is how it works in the northeast where I am.
abrowning is offline   Reply With Quote
Old 07-25-2017, 06:09 PM   #4
Melissa396's Avatar
Thanks for the reply. So it sounds like you don't think the retaining blocks will sink as much as the pavers?
Old 07-25-2017, 07:07 PM   #5
If the retaining wall blocks are just setting on dirt they may well sink also. Normally a retaining wall would be set on s footing but that might be overkill for a short wall.
Bud
Old 07-25-2017, 07:09 PM   #6
Rewards Points: 44
Unfortunately, no. The soil under it all will settle gradually. The sand will still settle a bit more even if you do compact it. You didn't mention what footing the wall is on.
Bud9051 gave you one way to address it. My way is similar and I would use a different paver style to make a decorative border.
Bud9051 likes this.
Old 07-25-2017, 07:14 PM   #7
Melissa396's Avatar
We put 4" of minus that was compacted with a hand tamper under the retaining blocks. So maybe the retaining blocks would still settle a little?? We will remove the pavers and add 1/4 to 3/8 more sand. Thanks for the comments!!
Old 07-25-2017, 07:26 PM   #8
I would use a flat plate compactor and not a hand tamper on top of those pavers. With a good tamper you can usually work them down as much as needed. Can't pull them up but down is related to how long you work them.
Bud
Bondo likes this.
Old 07-26-2017, 02:50 PM   #9
Rewards Points: 1,042
And the size compactor you use, get a 3500/4000 lb. compactor or you'll be at it forever.
Canarywood1 is offline   Reply With Quote
Old 11-28-2017, 10:11 AM   #10
Melissa396's Avatar
Thanks so much for all the advice - here’s the finished patio.
Need advice on compacting a raised paver patio please!!-896f8e35-870d-4056-ab03-88d2eb8e63eb_1511885454379.jpg   Need advice on compacting a raised paver patio please!!-52770628-7ac9-44bc-a83f-b9b7e0f57cf0_1511885474936.jpg   Need advice on compacting a raised paver patio please!!-13855699-38eb-4127-ba6d-0cef8eec9c74_1511885498239.jpg
SPS-1 likes this.
The Following User Says Thank You to Melissa396 For This Useful Post:
jlhaslip (11-28-2017)
Raised patio at doorwall question WoodworkerDave Building & Construction 1 05-25-2013 07:03 PM
paver patio + water Fix'n it Concrete, Stone & Masonry 1 05-13-2013 03:20 AM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
new deck or paver patio meth Landscaping & Lawn Care 7 06-06-2008 05:20 PM
