My Sprinker Will Not Shut Off - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-09-2016, 07:04 PM   #1
Rewards Points: 67
My Sprinker will not shut off
One of my zones of my underground sprinkler would not shut off yesterday. I have since turned the supply line off. I believe I need to change one of the valves but not exactly sure what to purchase. Here is a pic of my box. Can someone please help? Thanks!
https://www.dropbox.com/s/78cru74jo9d8vvx/2016-06-09%2018.12.40.jpg?dl=0
tate16t is offline   Reply With Quote
Old 06-10-2016, 07:08 AM   #2
Rewards Points: 188
Re: My Sprinker will not shut off
Search for Irritrol. If you did down, you should see some markings. It's likely a bad solenoid. They unscrew from the valve. Try swapping with one of the working valves.
Dan
djlandkpl is offline   Reply With Quote
Old 06-11-2016, 10:13 PM   #3
Msradell's Avatar
Rewards Points: 818
99% of the time a bad solenoid will cause the opposite problem, the zone will not come on instead of turning off! I'd be more inclined to think that there is some foreign material locked inside of the valve or the spring that keeps the valve closed has broken. It's very easy to take the valves apart and repair or replace the inner workings without actually having to do any plumbing.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Capping bathroom sink shut off valves. nowwhatnapster Plumbing 10 04-01-2013 12:17 PM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 12:29 AM
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 02:47 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 02:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
