Mulching Blade Or Not - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By ChuckTin
  • 1 Post By Mystriss
  • 2 Post By ChuckTin
Old 06-10-2019, 01:47 PM   #1
Dave Sal's Avatar
Rewards Points: 1,176
mulching blade or not
Hey guys and gals,
Last year I purchased a new lawn mower blade from Amazon, as local stores don't seem to carry one that fits my mower. Reading Amazon reviews convinced me that this was a mulching blade, but after using it this year I'm not so sure. Attached are two pics that I just took after cutting the grass. There are clumps all along the grass following the path that I take, and when I turn around on the driveway, I get a bunch of grass clippings there as well.
This is the blade on Amazon...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The lawnmower is a Craftsman 21" rear drive with a Honda engine. If anyone has any recommendations for a 21" mulching blade with three mounting holes that does a great job I would appreciate it. Thanks
Dave Sal is offline   Reply With Quote
Old 06-10-2019, 01:55 PM   #2
Rewards Points: 94
Re: mulching blade or not
The blade does have the laid over "S" of a mulching blades.
But "mulching" is a rather plastic term.
ChuckTin is online now   Reply With Quote
Old 06-10-2019, 01:55 PM   #3
Rewards Points: 7,001
Yep! That is what happens when you have a mulching blade. The accumulated clippings fall out over hard surfaces.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 06-10-2019, 02:52 PM   #4
Hammered Thumb
Rewards Points: 2,054
I have 2 craftsman mulching mowers same blades as your Amazon purchase. The older one spits and clumps more as it has the small area into the rear chute messing up the aerodynamics. The new one has an insert to fill up that small area when the rear door is closed, and it is much neater.
I'm sure you know the length/amount of grass directly correlates to how much can recirculate underneath before being dropped, so I've been having to mow sooner than 7 days to avoid your photos. Even with that I'm having to lift the front a little before the turn or onto hard surfaces to spread it around a little, I assume with our rains the grass is just too saturated and heavy even though shorter.
3onthetree is offline   Reply With Quote
Old 06-10-2019, 03:17 PM   #5
Dave Sal's Avatar
Thanks for the replies. Glad to know it is in fact a mulching blade. Guess I'll have to try to cut the grass more frequently.
Old 06-10-2019, 05:09 PM   #6
Naildriver
chandler48's Avatar
Rewards Points: 4,278
I use Gator Blades on my Kubota ZD21. They seem to cut the grass finely enough, as it is repeatedly vacuumed up and recut. https://www.ebay.com/itm/Blade-Kubot....c100008.m2219
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Dave Sal (06-10-2019)
Old 06-10-2019, 05:58 PM   #7
Rewards Points: 94
I think the mulching blades that really work are the double blade ones. Everything else "sorta" works. The wavy blades fall into that category.
Just took a set off our Rider and put on the factory set. We just don't have enough grass yet this year to really have put them to work.
The moral of this story? Guess I've got to match the blades to the task. Fortunately the rains seem to have arrived and I'm expecting to be able to use the mulchers again come July.
Dave Sal likes this.
Old 06-11-2019, 08:24 AM   #8
I open the chute and let the clippings fly earlier in the season and then close it and mulch when the grass is drier. Otherwise the mulching action works the snot of my 9HP rider.
Colbyt
Old 06-11-2019, 08:57 AM   #9
Rewards Points: 94
Clogging doesn't help.
Old 06-11-2019, 01:24 PM   #10
Mystriss's Avatar
Rewards Points: 3,370
We use mulching blades on the lawn tractor, you have to smack the deck on the ground a few times before going across the driveway so it doesn't drop the clippings there - also if you go too long it'll make track piles everywhere. My husband also has a habit of mowing damp grass which leaves the track piles too.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 06-11-2019, 02:25 PM   #11
Rewards Points: 94
Dry grass is probably a key to making them work properly.
Dave Sal and Mystriss like this.
