Mulcher Blades - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By chandler48
Old 06-06-2018, 12:44 PM   #1
Rewards Points: 168
Mulcher Blades
Assuming the size and fit is correct, can a "mulching blade" be out on any mower?
giddyap is offline   Reply With Quote
Old 06-06-2018, 01:12 PM   #2
Rewards Points: 1,550
Re: Mulcher Blades
Yes, if it fits. And if it has enough horses, probably, maybe, sort of, it may kind of mulch. May work a little better if a deck mulching plug is available for it or you can rig a way to close the discharge chute opening.
Old 06-06-2018, 03:20 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,218
Re: Mulcher Blades
If you don't have the mulching plug the blade won't matter.
If you do have one... the blade only matters a little.
Old 06-06-2018, 03:22 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 4,294
Re: Mulcher Blades
The best I have found is Gator Blades for my Kubota ZD21. Even without the chute blocked it seems the design of the blade keeps the clippings in the chamber longer and they are finer when they do finally emerge out the chute.
joecaption and Mike Milam like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-06-2018, 07:18 PM   #5
Rewards Points: 17,912
Re: Mulcher Blades
That's all I use is G6 Gator blades.
There thicker, wider and far harder.
If you go on the Oregon website and have the OEM # or even better yet the length (the length is not the overall lenght it's measured on the diagenel) and the arbor size and style)
Once you have that part number you may be able to find them cheaper on Ebay.
I buy all mine there because I get free shipping and order at least 10 at a time.
Will these jigsaw blades work? harryhh Tools 8 09-01-2017 04:03 PM
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 11:27 AM
Ridgid Saw blades kevsprojects Tools 12 03-17-2012 07:16 AM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
