Mulch That Won't Wash Away After Rain - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Bondo
  • 1 Post By Dave Sal
  • 1 Post By SPS-1
Old 08-21-2019, 12:10 PM   #1
Dave Sal's Avatar
Rewards Points: 1,164
mulch that won't wash away after rain
Hello all,
I have an asphalt driveway with a raised area from a tree root. As a result, water no longer flows down the driveway to the street so I installed a channel drain between the fence and the driveway, just before the raised asphalt. The drain works well until the wood mulch that I use along the fence floats away and clogs up the drain. I have to go out in the rain and constantly clear the mulch from the drain or the driveway floods. I initially thought of replacing the mulch with lava rocks but just read that these things float as well, so it doesn't sound like this is the solution.
Wondering if anyone has any suggestions. Thanks
Dave Sal is online now   Reply With Quote
Old 08-21-2019, 12:17 PM   #2
retired framer
Rewards Points: 20,332
Re: mulch that won't wash away after rain
We see mulch made from old tires now, it doesn't float but water will still wash it away.
What about gravel.
Do not use flat bottom gables with scissor trusses.
Old 08-21-2019, 02:10 PM   #3
Rewards Points: 12
Everything will float away. You need another solution, a barrier of some type.
Richardya is offline   Reply With Quote
Old 08-21-2019, 02:29 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Originally Posted by Dave Sal View Post
Hello all,
Ayuh,..... Washed 1" or 2" stone,.....
'round here the choices are gray crushed limestone, pink granite, or white marble, all available in bulk, from local quarries,.....
Local as in 40 miles,....
lenaitch likes this.
Old 08-21-2019, 02:33 PM   #5
Dave Sal's Avatar
What about gravel.
I thought about gravel but maybe a larger version so it's not too messy. Thanks for the reply.
Old 08-21-2019, 02:35 PM   #6
Dave Sal's Avatar
After reading Neils post this is what I was thinking about. I'll have to check what colors are available but this is probably the solution I was looking for. Thanks
Bondo likes this.
Old 08-21-2019, 04:40 PM   #7
Rewards Points: 7,528
Visit a landscape supply store
Dave Sal likes this.
SPS-1 is online now   Reply With Quote
