Metal-Wood Gate - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 04-25-2019, 10:36 PM   #16
Rewards Points: 132
Re: Metal-Wood Gate
Originally Posted by Nealtw View Post
All our house here have a foundation mostly concrete so we don't put the post in a concrete we just bolt the post to the foundation below grade with a 2x4 spacer between the post and the foundation which usually means the post is near but not touching the siding of the house.
Never thought of that. How deep do you go?
You epoxy in anchors or just use lag bolts?
Ive got about 18 foundation above grade (formed concrete) and then the EIFS starts which is about 2 1/4 thick.
Vanner is offline   Reply With Quote
Old 04-25-2019, 11:04 PM   #17
retired framer
Rewards Points: 20,340
Re: Metal-Wood Gate
You would like to have 12 to 14" inches between 2 bolts.
5/8" HDG wedge anchors, You would want a rotary hammer drill with 5/8"bit for that and a regular 5/8 bit and drill for what ever you are bolting there.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
Vanner (04-26-2019)
Old 04-26-2019, 07:24 AM   #18
Rewards Points: 132
Re: Metal-Wood Gate
I assumed there would be suppliers of something similar to what Ive seen online but cant find any kits that include gate frame and hardware. Would this style all be custom?
Thinking 5 wide gate, handle set, self & soft close.
Old 04-26-2019, 07:30 AM   #19
retired framer
Re: Metal-Wood Gate
Every city has Iron Work shops that could make that up for you
Old 04-26-2019, 12:32 PM   #20
Rewards Points: 132
Re: Metal-Wood Gate
Alright, so I'll have to come up with sketch for the post w/ flange for the wood slats - maybe have them fabricate the wall post with an offset to allow bolt-to-foundation.
Looks like 3x3 aluminum posts in most of the pics I see online.
Once the posts are set I can get a site measurement for the gate.
Given we want to put a handleset on this instead of std latch, what tolerance am I looking to be withing? 1/8"
Wood fence and metal posts Kieran68 Building & Construction 8 06-23-2017 03:52 PM
why do i need to paint my house? homie Painting 17 07-04-2015 02:04 PM
Wood fence gate issues AL C. Building & Construction 5 05-14-2014 09:05 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
