Make Driveway Wider - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 05-17-2019, 04:20 PM   #16
retired framer
Rewards Points: 20,734
Re: Make driveway wider
Does it still work and where does the water go, you do want drainage behind your wall too.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 05-17-2019, 04:23 PM   #17
Rewards Points: 62
Yup... I just tested it out and it still works. Yes. We would like to have drainage for our retaining wall... So in that case I'm just not sure how to fix it up.
wrender is offline   Reply With Quote
Old 05-17-2019, 04:24 PM   #18
Rewards Points: 62
Here is a closer up picture. I've just stuck a peice of wood in the end that drains.
Old 05-17-2019, 04:38 PM   #19
retired framer
Run water it for a while and look and listen to where it goes, if it is sending water around you foundation you don't want to use it but if it going to a french drain in the yard or out to a ditch then you use it. If you are going to use it having holes that let water in is not a problem, a half pipe of a bigger size fit over it would keep the dirt out.
Old 05-17-2019, 05:36 PM   #20
Rewards Points: 62
Ok. Thanks for the advice again. Another question. The gas line is now marked and runs parallel to the wooden retaining wall, 2.5' out from it and out to the street. We want to bring our new retaining wall out 12' from the house and then do a small 90 degree turn into the lawn. Then have a block stair case that goes up from the driveway. Can we do this stuff over top of the gas line?
Old 06-08-2019, 01:37 PM   #21
Rewards Points: 62
We have built the retaining wall. It is permacon celtik blocks. And they are stepped back. The problem is now that the wall is up, and we only backfilled half way up the wall (We ran out of clear stone), the wall is not level on the top. It is slanted somewhat in towards the dirt side. Is this a normal thing for stepped up retaining walls? And is it acceptable to leave it like this?
Old 06-08-2019, 02:33 PM   #22
retired framer
Your wall looks good, I wouldn't be to concerned if it is leaning a little to the dirt side.
Did you compact the base before you started?
Old 06-08-2019, 02:55 PM   #23
Rewards Points: 62
Ok. Thank you. Yes. I hand tampered it a lot and it was very level at the base.
Old 06-08-2019, 02:57 PM   #24
retired framer
The weight of the gravel behind the wall may have compacted the base a little more.
Old 06-08-2019, 05:47 PM   #25
DoomsDave's Avatar
Rewards Points: 5,696
VERY NICE WALL @wrender !
Forget my advice not to build one earlier . . .
I recall that you're supposed to lean it dirtside just a bit for extra stability, especially if it's really high.
Again, very nice.
DoomsDave is offline   Reply With Quote
Driveway Geotextile ETD66SS Building & Construction 35 08-29-2018 11:21 AM
Run-Off Issues from Driveway to House Logan176 Building & Construction 9 08-10-2016 11:54 AM
Driveway repair + brick border PTS Concrete, Stone & Masonry 12 06-16-2016 10:20 AM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-04-2013 11:06 PM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
