Low Voltage On Sprinkler Controller - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-29-2019, 09:45 PM   #1
Rewards Points: 2
Low voltage on sprinkler controller
Got an old rain bird ESP-12LX controller with 11 active zones including one that will not come on. Checked voltage at controller and all 11 zones including bad one show 5 volts which seems really low. Possible that the low voltage could cause only 1 of 11 zones to not come on? Seems like they would all work or none would work since same voltage on all. Or do you think could be problem in valve box for that zone? Itís buried or covered somewhere in yard so will have to find. Does that inexpensive chat r box really work to find the valve solenoids?
Brantley is offline   Reply With Quote
Old 05-05-2019, 02:47 PM   #2
Rewards Points: 578
Re: Low voltage on sprinkler controller
You would need to measure the voltage at each solenoid. Normally the solenoids operate with 24VAC power. If all of the zones show 5 volts then you may have a bad controller.
Calson is offline   Reply With Quote
Old 05-05-2019, 04:53 PM   #3
Rewards Points: 7,510
...or a bad AC adapter
SPS-1 is online now   Reply With Quote
Old 05-23-2019, 02:22 PM   #4
Rewards Points: 578
The adapters are simple transformers with no electronic IC's to fail. They are also converting AC to AC and so no diodes as with AC to DC converters.
Yard Sprinkler Talk Mr.Boots Gardening Forum 2 05-15-2017 02:48 PM
Analog multimeter shows voltage even with 3-way switch off OCPik4chu Electrical 17 09-25-2012 12:20 PM
Phone wires with line voltage Hexamexapex Electrical 20 07-01-2012 12:56 PM
Convert sprinkler controller from hardwire to plug-in lancetb Electrical 13 06-12-2012 06:01 PM
What should be VOltage Across 2HP 230V Franklin Pump Controller cb1234 Electrical 10 02-17-2011 11:04 AM
