DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   low presure on sprinkler system (https://www.diychatroom.com/f16/low-presure-sprinkler-system-143035/)
IJC 05-07-2012 04:03 PM
Here is my question, I'm on a well for my water, and the water presure for my sprinkler system starts off strong. Then after about 2 min the presure drops. I was told that the pipe for my sprinkler system was after the presure tank, that the pump could not keep the presure up on the tank there for the drop in presure. So it was suggested that I have the pipe for my sprinkler system move to the pipe that is coming right from my water pump. I did do that, now it worse than it was before. Any reason why?
user1007 05-08-2012 02:26 PM
Have you calculated the total flow and pressure demand of your sprinkler system? Lawn sprinklers need fairly high flow rates in gallons per minute (GPM) and high pressures too. Drip irrigation works in gallons per hour and at low pressure.
To start. Do a simple addition of the requirements of both water and pressure demanded by each head or emitter. Does this come close to the output of your pump?
I am guessing you are water flow rate as much as water pressure. You may have a leak somewhere too?
IJC 05-08-2012 04:17 PM
low water presure
Thanks, I'll check into the flo rate.
user1007 05-08-2012 04:30 PM
You might also think about converting anything but turf to drip irrigation. You can get GPH emitters from about .5 to 12 gallons per hour in just about any configuration you can imagine from simple drip things to misters, bubblers and even things that look and act like little rainbirds. Drip works under low pressure and simple systems like I once designed are exactly as exciting as watching paint dry.
If you buy from an irrigation supplier it is cheap, easy to install and plants love it. One drawback is most that works well has to be on the surface but plants will grow so nobody notices it.
Not much in drip technology has made it to turfgrass yet though. But when designing I was usually able to convince people to plant other things but lawn. Next to maybe a conventional, not a natural (as is the trend) pool it is the highest of any landscape maintenance elements.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
